boost elbow or "T"
Old 06-14-2005, 08:51 PM
Txwelder's Avatar
boost elbow or "T"
Instead of buying a new elbow for the turbo to adjust boost, why couldnt you just put a "T" in the line that is adjustable? Just a thought, tell me if Im wrong.
Old 06-15-2005, 07:53 AM
RowJ's Avatar
If your talking about some kind of pressure regulator...that's what is used on an external wastegate (see gallery). Works well! Probable more expensive, No?
RJ
Old 06-15-2005, 05:41 PM
Txwelder's Avatar
Im not talking about anything that fancy, just a "T" fitting in between the compressor and exhaust housing in the rubber hose that has an adjustable screw on the end not clamped to the hose. Same concept as the elbow having an adjustable screw but this could be placed someplace more convenient and not have to tamper with the turbo itself. Just a thought.
Old 06-15-2005, 06:40 PM
Cummins4Life's Avatar
Would a needle valve work?
Old 06-16-2005, 05:18 PM
Txwelder's Avatar
Yeah that is the idea I had in mind' just have to find one. Do you know what size of tee Iwill need?
Old 06-16-2005, 05:55 PM
azcrawler's Avatar
Been using standard air tool/paint gun regulator forever on Grand Nationals and Turbo II Mopars. No reason it wouldn't work on a cummins... Nice part is that you can run the line in the passenger compartment and exhaust it back out. Voila... Adjustable boost controller from the driver's seat.
PEAKSTRYDE
10-11-2007 04:20 PM
dodgediesel
12-14-2006 09:54 AM
chuxtruk
05-12-2006 01:59 PM
triplenickel
08-23-2005 04:01 PM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: boost elbow or "T"
