Block over-bore
Old 12-15-2006, 09:10 AM
59FORD's Avatar
Question Block over-bore
Anyone know the max over-bore on a 5.9 that you can get pistons for.
I am not sure if you can do a +.060 bore and find pistons at a reasonable price.
I have an evil thought for the P build.
59
Old 12-16-2006, 09:35 AM
PeytonMaterne's Avatar
I'm not an expert but I have heard not to go more than .040, and most of the kits you see are .020 over. Why would you want to go .060 anyway? Unless the cylinder needs that much to clean it up, the increase in displacement isn't worthwhile. Plus pistons for these are expensive.
Old 12-16-2006, 12:45 PM
dpuckett's Avatar
I agree, why are you over boring it, anyway? If there is that much wear, then I'd go for it. But you will get ZILCH for extra power by boring alone. It is all about fuel, air, and timing.
Daniel
Old 12-16-2006, 08:27 PM
59FORD's Avatar
I am building a P motor and the block will more than likely
have to be bored. I wouldn't be afraid to take one to .060
there is plenty of meat. As far as expensive this will be my
3rd Cummins and I think they're priced cheap. My last VE build
had 2 sleeves in 1 & 2 and ran real strong. I just wasn't sure
on the over-bore size.
59
Old 12-16-2006, 08:30 PM
Begle1's Avatar
Daniel
Nonsense. There's no replacement for displacement.
More displacement means you can burn more fuel at lower pressures. Whether the extra ~.2 of a liter will make that much of a difference is questionable, however.
Old 12-16-2006, 09:25 PM
rockjeep73's Avatar
Took the words right out of my mouth.
Someones not gonna tell me that you cant fit more air into a larger cylinder.
Old 12-16-2006, 09:27 PM
The real replacement for dispacement is the turbo itself.
Old 12-16-2006, 09:39 PM
rockjeep73's Avatar
Same turbo, two different engines, one with a .060" overbore. Which one is going to make more power?
Old 12-16-2006, 10:29 PM
vette95's Avatar
I'm building my 5.9 right now and couldn't find .060 over pistons so I went w/ .030 and two sleeves. The brand that I was using was Mahle and wasn't availible. There may be other companies that do offer it since I didn't research heavily on the matter.
Old 12-17-2006, 08:10 AM
59FORD's Avatar
Glad to see some folks are into my way of thinking.
I'd like to a 426 (non hemi) CUMMINS out of a 5.9 block.
Can you say
Old 12-17-2006, 08:19 AM
If you mean 426 cubic inches, your not going to get that without a stroker crank. Look at the power guys are making with just the factory bore and stroke. I think you could use that money in another area and get more power and more return on your hard earned bucks.
Old 12-17-2006, 08:31 AM
"I say you burned a piston or two. Don't keep starting it you will only risk cracking a cylinder and have to have it bored and sleeved, I know I been there, done that and it ain't cheap." Quote by 59 ford
Old 12-17-2006, 02:46 PM
59FORD's Avatar
Uhhhhhhh yeah, I have burned more than a few pistons in my time. I
trust MY work on MY toys more than anyone out there. If I kill it, it's
mine and mine alone. IF you pay someone to build someyhing for you
it's either you can't do it or have too much money. You are trusting
that person with your parts and your money, if it BANGS who pays?
ALSO, The above piston and head are from my 5.9 that had 2 sleeves
in it and ran very strong. The dropped valve was not from anything I
did or didn't do. You can drop a valve on a $50,000 engine the first time
you fire it. Just ask the NASCAR boy's.
You can burn a piston and not hurt the block or head but a dropped
valve it another story.
BTW, what was ^ about???
Old 12-17-2006, 02:55 PM
59FORD's Avatar
WHY NOT?? The Ford 7.3 is 444 inches and with very weak rods and walls.
Why not stroke a 5.9 ? Why not bore a 5.9 out to say .125 or even .250
Remember an overbore of .250 bore is only .125 off the wall NOT .250
The bore is measured across not from the center to the wall.
Just $ .02 more.
Old 12-17-2006, 06:48 PM
dpuckett's Avatar
I was under the impression that FUEL made the power, not displacement. My mistake. I do like the idea of lower pressures to make the same power, as stated by Begle1. (many guys use marine pistons and lower the compression ratio) But, you add a turbocharger (or two), and displacement becomes secondary to fuel and air.
DP
Escursion12V
02-13-2010 06:48 PM
swank
12-26-2005 10:30 AM
deere nut
08-17-2005 11:38 PM
bigfoot
08-14-2004 02:22 PM
iwantaCUMMINS
04-04-2004 11:05 AM
Quick Reply: Block over-bore
