Big 47RH problems
Big 47RH problems
If I drive my truck for longer than about 30min I have all kinds of trans problems. First it'll start kicking in and out of lockup, then it'll hang up in 2nd gear instead of shifting to 3rd, the only way I can get it to shift to 3rd is to let off the throttle, it's also hesitant to go into O/D. Now it doesn't always do this, when I first start out it's fine, if I drive for awhile then it'll start. I replaced trans fluid, filter, and both batteries with no success. Any ideas? The trans fluid temp doesn't seem to have an effect, it'll be around 135* and act fine, 30min later still at 135* but now it's acting up. And I don't think it's electrical, because it'll start out shifting fine with no lockup problems. But after I've been driving awhile it starts acting up. Also if it's colder outside it seems to delay the problems, but the longer I drive it the worse it gets, sometimes it'll go away for like 5 min but it always comes back. What do you guys think?
But if it was something electrical wouldn't it be acting up all the time? I can about time it down to 30min before it sets in. That's what makes me think it's something internal wearing out.
Check your battery connections , I had probelms with a 91, would go into overdrive for about first 20- 30 minutes then kick out . Long story short cleaned terminals and everything returned to normal.
Richard
There's about 95k on the tranny. If I could just get the TC locking and unlocking problem fixed I'd be happy, because I plan on getting a new trans in Spring if not sooner. I'm gonna try cleaning my tps, but what grounds should I check? I already cleaned the terminals and put in new batteries. Thanks.
BigGreen96
10-18-2009 02:23 PM
