Better handling?
Old 03-26-2004, 10:03 AM
psalm69's Avatar
Better handling?
Any ideas on making an '01 2500 4X4 handle better? I like a good stiff ride and would also like to remove some of the sway. What have you guys done to make your trucks a little more car like in that way?
Old 03-26-2004, 12:39 PM
BigBlue's Avatar
The best thing I can think of, I've asked this question a couple of times, is new shocks and polyurethane bushings. That's about all that can be done. The stock shocks suck. Period. I'd go with either a set of Ranchos or Bilstiens (sp).
Old 03-26-2004, 02:33 PM
dsldan's Avatar
Make sure there is plenty of air in the tires........................
Old 03-26-2004, 08:17 PM
jaconst's Avatar
I'd try lukes link for your tie-rad and trac-bar ends and look into a steering stabilizer kit I can't remember who sells it maybe DT? go to links and check out what the cos offer.
Old 03-26-2004, 08:45 PM
gsdog1's Avatar
When I lifted the truck, I opted for dual shocks up front, after market steering stabilizers, and trac bar. Huge difference!
Matt
Old 03-26-2004, 09:31 PM
dodgeram's Avatar
I put skyjacker d25 springs and dual shocks on the front ............. tightened her right up handles awsome now
Old 03-26-2004, 09:52 PM
psalm69's Avatar
I may look into doing some of those mods. Thanks fellas.
Old 03-26-2004, 11:24 PM
dodgediesel4x4's Avatar
A dual steering stablizer kit would do the trick. Gets rid of the play, for the most part, in the "loose" steering. I think you would notice a big difference.
Old 03-27-2004, 09:25 AM
DTR's Cow Boss
DodgeCowboy's Avatar
belive it or not when i installed my hellwigs and set them to the max it lifted the rear of my truck a good 1" and it dramaticly took the roll and sway out of her
TIMMY22
11-02-2006 07:55 AM
ledj
09-09-2005 12:37 PM
P.O.R.
15
06-30-2004 04:16 PM
BigBlue
03-22-2003 12:45 PM
Quick Reply: Better handling?
