Best $2.77 AC mod.
Old 08-15-2011, 09:20 PM
C Schomer's Avatar
Best $2.77 AC mod.
I added some 134a to my AC last summer and I discovered the orifice tube is along the right fender (my battery box isn't there anymore) and them pendejos at Dodge didn't insulate the line from there to the firewall. I finally remembered to pick up some Armaflex and insulate it a couple of weeks ago and it made more than just a little difference. I should have checked some temps before and after but I didn't. The electric fans, up front, helped with slow driving but now I have cold cold air in 1 mile after start-up and I can freeze the gnards off a brass monkey if I want too and it was 106 today. The insulation is good to 220. I'll switch to fiberglass if it melts. Craig
Old 08-15-2011, 09:30 PM
maxwellp's Avatar
I have seen that line, with all the talking about the 3rd gen a/c. I am going to try this.
Old 08-15-2011, 09:48 PM
Administrator/Jarhead
madhat's Avatar
Huh. I'll try that when I get back...
Old 08-16-2011, 01:04 AM
Brewtus88's Avatar
makes sence... gets pretty hot there...
Old 08-16-2011, 08:22 AM
MikeyB's Avatar
Interesting. Did you use the 3/8" version?
MikeyB
Old 08-16-2011, 08:36 AM
railroaderone's Avatar
can you post a pic of the area. This would be great if I knew where to put it
Old 08-16-2011, 08:48 AM
AH64ID's Avatar
Thanks for the info.
Old 08-16-2011, 09:29 AM
Shorts's Avatar
Ayyee, worth a look. Thanks C. Also, the description of the Dodge guys, been around that word all my life, first time seen it typed in a forum post
Old 08-16-2011, 07:01 PM
Hunter11's Avatar
Looks like the smallest I can find at Lowes or Home Depot is 1/2". Wonder if that would work.
Old 08-16-2011, 09:12 PM
rockcrawler304's Avatar
Thanks for the heads up... I know what I will be looking at tomorrow
Old 08-16-2011, 09:16 PM
C Schomer's Avatar
Look for a hvac/r supplier. Refer tubing goes by the OD and we have way more ODs in the smaller sizes (1/8, 3/16, 1/4, 5/16, 1/2, 5/8 and 3/4) than plumbing. Plumbing copper goes by the inside nominal dimension. The line I insulated is 1/2"OD. Our 5/8" is 1/2" to a plumber and our 1 1/8" is 1" to them. I used 1/2 x 3/8 - 3/8 wall thickness, 1/2 ID and that was tough enough to get in there. The Johnstone Supply pt# is B92-124. It's not presplit. I split it with a razor knife and slid it over the line little by little and stuck it back together with contact adhesive, about 3" at a time. It wasn't fun but it sure was worth it. I just looked in Graingers and they don't have that size. They've been trying for 20 yrs to get a cut of the hvacr business and they don't know how to do it right. The big brand AC dealers should have it if they have a parts dept. - Carrier, Trane, York McQuay etc. Craig
Old 08-16-2011, 10:30 PM
2500's Avatar
excellent idea!
Old 08-17-2011, 08:24 AM
maxwellp's Avatar
Talking
GRAINGER Page 4062
Grainger Item # 2CKE8
Price (ea.) $2.83
Pre-Slit, Pre Glued,
Old 08-17-2011, 08:45 AM
sr4440's Avatar
help out the dummy please. is it the line going into the Accumulator or the other line?
Joe
Old 08-17-2011, 08:53 AM
maxwellp's Avatar
Other line, the accumulator is in the return side, But you could do both sides.
Quick Reply: Best $2.77 AC mod.
