bent push rod, other damage?
Old Oct 7, 2007 | 07:02 PM
rootremblay's Avatar
While putting the rocker assembly together on the #6 cylinder on my truck the 2nd to last push rod didnt fall all the way into place. While tightening the head bolt it bent the push rod. do you guys think I damaged anything else? I found this out because the motor wouldnt turn over to adjust the valves so I checked the pushrods.
Old Oct 7, 2007 | 07:32 PM
Dshiftff's Avatar
I would just check the ball on the rocker pedistal that sits in the top of the pushrod tube. Other then that get a new rod and button her up.
Old Oct 7, 2007 | 07:59 PM
Fred Swanson's Avatar
Yeah, less than $3 for a replacement from Cummins.
Old Oct 7, 2007 | 08:11 PM
thanks for the help, thats what I thought also. but I know there are alot of yall around here that have much more experience than me.
Old Oct 7, 2007 | 08:55 PM
logskidder's Avatar
This is common on the B and C series...the pushrod feels like its seated but its not. The pushrod is the weak link and will bend before anything else gets damaged. Check everything out....but you'll be ok. Ive seen it happen a bunch of times....you know the deal, its 2:00am....tech wants to go home and a pushrod gets bent.
Old Oct 8, 2007 | 08:51 PM
twinturbos's Avatar
I know that this is a kida off subject, but i was adjusting valves on my truck and after i got them all adjusted right i went to torque the lock nut at 18 ftlb's and busted that adjusting screw right off. flush with the rocker.. would that bend a pushrod, breaking it off like that.?
1stGen72
Feb 2, 2009 11:51 PM
2006BLKMegacab
Jan 2, 2009 06:25 PM
rootremblay
Oct 8, 2007 05:25 AM
ciscohusker
15
Feb 26, 2007 03:40 PM
dodgec68
Feb 12, 2007 01:23 PM
