Is the the ball joint going bad
So for the last month or so I've had this odd click happen somewhere in the steering linkage whenever I'm at a sharp steering angle. Usually in the neighborhood of 85% of a maximum turn. Would this be the infamous ball joint going bad? I just hit 80k on the truck and have heard that this is about when this happens, or that it should have by now (don't worry I've already had the lift pump replaced).
Thanks for any input
Chances are that it is your u-joint making the clicking noise. Raise axle one side and rotate tire by hand and listen, turn steering right or left check again. Ball joint check put a bar under the tire and lift, watch for movement in lower joint, bearing check grab the coil spring with one hand mid way rotate tire,if bearing going bad you should feel grinding(vibration) in coil. When you change one part or another you might as well do both ball joints and u-joints, bearings only if bad (PITA to remove if never been touched).
this post will help if it is a joint or ball joint...
https://www.dieseltruckresource.com/...76#post2210376
72dart
06-19-2012 10:42 PM
Wulzcat
12-19-2009 05:15 PM
wcbcruzer
22
04-30-2008 06:58 PM
FDC
07-16-2007 12:51 PM
Treangen
05-07-2007 03:10 PM
