B&M Transmission plug....
Old Jul 11, 2005 | 02:35 PM
sajigore's Avatar
I put one of these in today and cannot keep the plug from leaking. Any Ideas.....
Old Jul 11, 2005 | 03:17 PM
P.J's Avatar
P.J
Did it go in smooth? Threads seem alright?
Old Jul 11, 2005 | 05:21 PM
Dodgezilla's Avatar
Did you use the gaskets they provide? Mine has been on for almost two years and never a leak. You have to make sure to hold the nut on the inside while you tighten the outside....
Old Jul 11, 2005 | 05:44 PM
MikeyB's Avatar
I have installed a few B&M transmission plugs on several of my vehicles in the past. I did have one that leaked from the little drain plug after installation. The rubber seal on the plug wasn't doing it's job so I removed the plug and used teflon paste on the threads and that stopped the leak.
MikeyB
Old Jul 11, 2005 | 08:18 PM
sajigore's Avatar
It is leaking from the little plug in the center. I thought they would have some sort of rubber seal or somthing but it was just a metal plug. I am going to have to drain it again tonight and put some RTV on it to see if that stops it.
Old Jul 13, 2005 | 07:19 PM
Dodgezilla's Avatar
Come to think of it, I think I just put some Black RTV on the plug because I was afraid it might leak. It worked....
Old Jul 15, 2005 | 12:16 PM
FRANK M's Avatar
That center plug is a pipe plug. Use a back up wrench on the larger nut and tighten the smaller one a little more.
royta
Nov 25, 2016 11:48 AM
mstep3
Mar 17, 2011 08:46 AM
billmac
Jun 21, 2010 05:24 AM
ctturbodiesel
Dec 13, 2006 09:37 AM
