Auto door unlocker
Old Nov 22, 2009 | 02:58 PM
leeboy's Avatar
Auto door unlocker
When i bought my truck, it came with only one auto door unlocker....Now this one is not working so well with a new battery even....Is there any place to get these things without paying Dodge full price? I hate using the key....!
Old Nov 22, 2009 | 03:44 PM
Doj Dewd's Avatar
you could also look at an aftermarket system. go to a couple places which deal with aftermarket auto/electronics, tell them your problem and se what they recommend. an entry level auto-security system might be cheaper than a new remote from dodge . . .
Old Nov 22, 2009 | 06:48 PM
mechrisme's Avatar
could it be your doors locks? I knew someone with a 98 I say and his power locks starting to give up
Old Nov 22, 2009 | 10:01 PM
leeboy's Avatar
How bout something like this ?
http://cgi.ebay.com/ebaymotors/1999-...item19b7dca5a9
Old Nov 23, 2009 | 04:34 AM
mechrisme's Avatar
isn't that for a van?
Old Nov 23, 2009 | 05:56 AM
Burrhead's Avatar
Mine started acting up a while back too. New batteries, still nothing. I took mine apart and cleaned the rubber pads and the areas on the circuit board where those pads touch, with a Q tip and rubbing alcohol. Put it back together and it works perfectly again.
You'd be surprised how much dirt there is under the rubber pads.
Old Nov 23, 2009 | 09:34 AM
leeboy's Avatar
I will give it a try Burrhead.... I have one for my 2003 Dakota still. i wonder if it can be programmed to work with a 99 Ram Diesel?
Old Nov 30, 2009 | 09:28 AM
leeboy's Avatar
Cleaned my thing and it still dont work....Someone must know a cheap place to buy one....Not sure if i trust ebay....
Old Nov 30, 2009 | 10:08 AM
johnh's Avatar
i bought a pair of oem units off of ebay for my pontiac, i had to have them programmed at the dealer for 10 dollars...........
maybe yours needs the reprogramming
Old Nov 30, 2009 | 10:43 AM
D2 Cat's Avatar
I'd suggest you repair/replace your key fob with factory items. You can purchase them off of Ebay, just be sure the number on the back of the one you have matches the one you purchase.
If you go with an aftermarket system there will come a day you'll wish you had made a different decision. When they fail you now have a mess of wiring to figure out and replace. Just do it right the first time!
Old Nov 30, 2009 | 05:24 PM
dkenny's Avatar
did you try resyncing them with the truck? check the manual..my 2000 has a section for doing this..
-dkenny
Old Dec 1, 2009 | 08:21 AM
leeboy's Avatar
-dkenny
That could be a idea, i didnt get the manual with my truck....its a 99.... Anyone know the steps?
Old Dec 1, 2009 | 01:08 PM
wahoo209's Avatar
Don't know the steps for that but I do know that I bought one off ebay and it worked fine but I ad to have it programmed at the dealer ($35). My actuators recently quit so I am now going the aftermarket keyless entry route. For about $100 you get keyless entry and basic alarm system.
Brambles
Dec 22, 2008 09:51 AM
Bobcat698
Apr 24, 2005 07:56 AM
Patrick Campbell
Dec 16, 2004 01:53 PM
svmopars
Oct 27, 2004 06:35 PM
Chazman
13
Jul 20, 2004 03:04 PM
