ATS diesel injectors
Old 07-20-2008, 11:36 PM
dodge_diesel's Avatar
Can someone tell me how these performe? and I was on there web site and they have a $1000 core charge??? do they lope and haze at idle? I was looking for some big hp ones but I havent heard of anyone using these
Old 07-21-2008, 01:55 AM
12VBLacKCLouD's Avatar
Nobody here is a fan of ats. That being said, look into F1 diesel for some quality injectors.
Old 07-21-2008, 03:06 AM
Diesel Doc's Avatar
+10 on the f1's. You will def get what you pay for. I run the mach 6's on my 02. no haze, no problems.
Old 07-21-2008, 10:24 AM
The Guru
Mike Holmen's Avatar
I run mach 6'rs for three years now. They smoke some until you build-up boost and run too hot for heavy towing. If you're looking at twins the S400 primary will clear the smoke faster than the 3B will. Run a garrett bb GT37 for the secondary and will have the prefect street/strip twins. There are better set-ups, but will cost more $$$ and you'll only make a few more ponies.
Old 07-21-2008, 10:44 AM
I was looking at the mach 7s, will these haze and lope and will it keep up with the ip
Old 07-21-2008, 11:05 AM
Diesel Doc's Avatar
I was told by Olee Poole that the 7's do haze some but I havn't seen it myself. Call Dan at f1 He is a super guy and will answer any questions you have. I thik I have the # if you need it.
You will need WAY more turbo or twins for 7's
Old 07-21-2008, 11:18 AM
ok its either mach 7's or II super dragon flow, I dont know what are better but im really leaning toward the mach 7s does anyone have the number
Old 07-21-2008, 04:14 PM
The Guru
You can only get the injectors so large, after that the power will start to drop off. The difference between 6 and 7's is up to Don on how much they will flow. You'll have to get them flow tested to see if they are the big bad ones. I find that the stock SO pump will not supply enough fuel to keep fuel in the pump after a hard pull, with a drag/smarty stack. It might be good enough with a brand new VP, but the don't stay that way for long.
Old 07-21-2008, 04:35 PM
Diesel Doc's Avatar
704-855-2679 that is Olee Poole's #give him a call he builds some bad trucks for sled pulling and drag racing and has a bunch of experience with the 7's and maybe even the 8's he will be able to point you in the right directon.
KRB
05-20-2007 06:20 PM
RyeThomas
08-18-2006 08:49 AM
chw
0
06-16-2006 06:51 PM
BIGOKIE
07-21-2004 05:53 PM
GaryMaines
01-20-2004 11:52 PM
Quick Reply: ATS diesel injectors
