Off Road / 4x4 OffRoad discussion, along with 4x4 events and information.
Anyone know anything about INTERCO TRXUS tires?
Old May 24, 2006 | 12:43 AM
VikingDiesel's Avatar
Found a great deal on some, wanted to hear some feedback from anyone first
Old May 24, 2006 | 10:19 AM
ptgarcia's Avatar
In general, Interco makes one hell of an off-road tire, but typically lack good on-road manners. They can be extremely loud and wear quickly. If you do lots of highway driveway I'd look elsewhere for a more rounded tire. Good luck!
Old May 24, 2006 | 10:29 AM
derek840378's Avatar
i've never owned trxus sts but what i hear from magazines and friends is they are good on the road and sand, and pretty much nothing else. and yeah they do wear pretty quickly.
Old May 24, 2006 | 10:30 AM
JD Dearden's Avatar
That perticular tire there in your pic is very good in the sand but you coulden't give me a set of those.
Old May 24, 2006 | 10:44 AM
I can get a set of (4) for dirt cheap so I want to jump all over it, just a few qs:
1. will they fit my stock 17x8 rim?
2. Is the load rating ok?
Link
I am NOT sure if its the STS or M/T that I am getting
Old May 24, 2006 | 10:51 AM
got a q for you. what size are they? load rating will depend on which size they are. they one you had pictured is the sts. the mt i hear is better in mud/rocks but not quite as good on the road, yet still poor mileage. also if they are sts's pray they are the radials.
Old May 24, 2006 | 10:58 AM
33/12.5/17 is the size, I know they are radials, I just have to find it if they are STS or M/T. Whats the difference between radials and Non-radial, I always forget.
Old May 24, 2006 | 11:09 AM
not 100% sure but it something to do w/ the metal bands in the tire. i believe in a radial they run around the circumference, bias are across or diagonal to the tread. the bias always have a rough ride until they warm up, especially when its colder weather. as far as a street tire, radials are definately the way to go! someone correct me if im wrong.
Old May 24, 2006 | 11:22 AM
JD Dearden's Avatar
Honestly those tires are not practical for anything but off road use and sand dunes. However it depends on how you use your truck if you just whip it around town and want to look good get them. They will be bad for highway use and towing they float on you and make alot of road noise.
Old May 24, 2006 | 02:44 PM
I just want to make sure they will be safe on my truck b/c of the LOAD rating.
Old May 24, 2006 | 02:48 PM
ds1rider's Avatar
I'd stay stock before going to those.
Old May 24, 2006 | 02:52 PM
NO towing, (maybe once a year local within 50 miles) cruising around town and want to look different is pretty much what it'll be and to and from work.
Old May 24, 2006 | 02:58 PM
JD Dearden's Avatar
Then get them besides you can always replace them.
Old May 24, 2006 | 03:12 PM
I wonder how long they last?
Old May 24, 2006 | 03:13 PM
JD Dearden's Avatar
Probably 25,000 to 35,000 thousand depending how good you about rotating them.
