airdog 100 replacement filters
Old 06-15-2010, 07:12 AM
coon-dog7070's Avatar
does anybody know the crossover numbers for airdog filter? baldwin fleetguard i just need to replace them bc theyve been on there for a very long time
Matt
Old 06-15-2010, 10:53 PM
1dumrednek's Avatar
i would also like to know that. also how often should we replace these filters?
Old 06-16-2010, 01:54 AM
99Dually's Avatar
FF5617(10micron),FF5613(3-5micron),FF5587(7micron). Some one may chime in to correct it if I put the number wrong. Hope it help
Old 06-16-2010, 08:11 AM
nickg's Avatar
replace filters when you notice a drop in fuel pressure, always carry a spare in the truck, (you dont need to replace the water seperator)
I go thu a tank of fuel every 2 days, and replace the filter once a yr! (almost 2000hrs of run time)
That being said it only takes one tank of fuel to plug up a filter
Old 06-16-2010, 11:18 PM
1dumrednek's Avatar
like a large drop or just a couple psi?
Old 06-16-2010, 11:19 PM
1dumrednek's Avatar
and maybe this is just me, but wouldnt the smaller the micron be better?
Old 06-16-2010, 11:32 PM
nasty01cummims's Avatar
Yes. Smaller micron=better filtration and is fine for a stock or moderately bombed truck but some of the higher hp trucks run a 7 or 10 micron filter to help with higher flow volume....maybe you understood that, sounds a little confusing to me and I'm the one that wrote it. Also another thing to think about is the fact that Air Dog might not honor their warranty if something other than Air Dog components are used.
Old 06-17-2010, 08:12 AM
nickg's Avatar
owerner of the company said they are fleetguard filters
https://www.dieseltruckresource.com/....html?t=196164
Old 06-17-2010, 08:41 AM
Thanks nickg. That's good to know
Old 06-27-2010, 06:39 PM
torqueman's Avatar
filters
Sure seems hard for u guys in the south to find these filters.It's even crazier to find them in Canada.Fass filters no problem to find...........
Old 06-27-2010, 08:06 PM
nickg's Avatar
cummins has the Fleetguard which screw right on to the AD, no issues finding them, just issues with pricing sometimes,
53 willys
38
11-06-2008 11:18 AM
jmccart
26
12-29-2007 12:29 AM
Spooler
12-26-2007 08:55 PM
Super Googan
29
12-23-2007 08:24 PM
6 2 Carl
04-09-2005 12:05 AM
Quick Reply: airdog 100 replacement filters
