airbox and a 4" hole
so if I put a 4" hole in the bottom of my airbox ,and run a dryer vent to exactley where , Id like feedback from someone whos done this ( was it a good idea ) if it wasnt (what went wrong)
THANKS
THANKS
You will not have any problems even if the down pipe was completely submerged in water, snow, mud, etc as long as the stock air box openings are NOT restricted!!!!!
If you have at least 2 (1 factory and 1 "custom") openings in your air box you CAN close one off 1 of them completely and still get full flow out of the other with out sucking up anything but air.
I've havent noticed any extra anything other than actually being able to hear the intake, over the whistle and the straight exhaust. But I am currently running a stock replacement filter so I believe if you were gonna gain anything with this mod you'd need a better flowing filter to take advantage of the extra inlet. Theres a website that charges like $99 bucks to do the same thing and they claim it's main achievement is lower EGT's while towing.
http://www.syntheticoilspecialties.com try here. Yes it's drop in.
If you wanna see what gain is possible, just go for a drive without the cover and filter for two blocks and then put it back on.
I live on the edge though. The purists should chime in here and tell you your motor will blow. I hope it doesnt, good luck to ya.
Disclaimer. The author of this post excepts no resposability for anything that may/may not happen to your vehicle or love life now or ever as a result of any advice or comment that he/she makes.
Works fantastic. very pleased
