Air Box Mods (Question)
Old May 20, 2004 | 11:23 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
I've done some reading on here about folks modifying their stock air boxes to get more air by either drilling holes in the bottom of the box or by putting a 4" or so elbow on the bottom. I've also seen lots of talk about water getting into these holes or into the elbow.
I haven't looked too closely at this yet, but how can water get in this area unless you have your hood up and you're spraying water in there?
This minor mod and a Pro Guard AFE replacement filter seems like an easy way to get more air to the engine.
Old May 20, 2004 | 07:26 PM
dodgedude361's Avatar
i have the PG7 drop in. i plan to open the air box as well. I probably will do the PVC elbo on the underside of the box. There are some other posts with instructions on how to do this. From what i`ve read, if you put some sort of mesh over the end of whatever tube you use, it will help keep the water out. Someone suggested using a pice of womans stockings, and others have said use a piece of screen.
I`m leaning towards the 4 inch drainpipe, with a screen mesh cover on it.
Just get creative, you will come up with something.
Old May 20, 2004 | 09:08 PM
Hoss's Avatar
I'm thinking of fabricating my own concrete airbox with vent holes.
Old May 21, 2004 | 06:25 AM
spots's Avatar
Some have concerns that water will be ingested when driving in heavy rains. I drove 200 miles in blinding rain and when I got home I opened the airbox to see if it was wet. It was not.
Old May 21, 2004 | 09:56 AM
fanofthewolf's Avatar
Check my gallery, I turned the elbow upside down, now if I want to "close" it I can put a cap on it inside the air box. It is too tight to do anything underneath.
Old May 21, 2004 | 02:07 PM
RankRam's Avatar
Thanks for the info spots!
I was wondering about that, but it doesn't rain much here in northern Nevada.
Old May 21, 2004 | 03:11 PM
BigBlue's Avatar
You would definately isolate the filter from any underhood heat, water, front end collision.
herb
Jul 18, 2008 08:25 AM
RSOPNCO1
Jul 10, 2007 09:29 AM
Dinner
13
Apr 8, 2007 10:23 PM
1969mach1
Mar 18, 2007 12:48 AM
guzzirider
Feb 19, 2007 08:01 PM
