AC Compressor, Whats the right way to fix the AC system?
Old 02-03-2009, 08:50 AM
jlipskoc's Avatar
My AC compressor bearing is shot, and the AC system leaks assuming the evap core is fault.
I bought a no AC belt to bypass the compressor for now.
I need to know whats the best way to do this the right way? Or If I take it to someone, what do you think the cost will be?
I was thinking:
Replace compressor, drier, evap, have someone vac and refill, what else should I replace?
Old 02-03-2009, 11:34 AM
nkennedy's Avatar
Replace the heater core while your in the box. It's not too expensive, and will save doing it later. Also check all your lines for cracks.
Old 02-03-2009, 11:45 AM
crabbelle's Avatar
i have a spare conpressor, drier and evap. they came outa my truck
Old 02-03-2009, 12:12 PM
cumminspower79's Avatar
Also, replace the orifice tube its the little inline filter in the system. In my 02 you have to replace the whole liquid line to change it, i think its the same way on your year.
Old 02-03-2009, 05:01 PM
mrclean's Avatar
I was thinking:
Just for the parts you listed, you're looking at @$500. Add $100 for a heater core(best to replace now while the case is out). Evac and refilling the system will vary, in my area it's @$130. That's over $600 for parts alone. And everything else is being replaced, you'd be ahead replacing the AC lines as well, add @$200. If you farm out the job, I would not be surprised if the bill was $1300-$1500.
wvfarmboy54
04-25-2010 10:04 PM
WhoCares79
06-03-2008 11:45 AM
Camarogenius
06-25-2007 08:55 PM
JKM
03-08-2006 03:23 AM
Quick Reply: AC Compressor, Whats the right way to fix the AC system?
