ABS system
Old Jan 20, 2004 | 10:30 AM
DODGE4X4's Avatar
I have had this happen to my trucks several times over the past years. In every case it has been the sensor on top of the rear diff. The sensor runs about $50 or so and is easy to replace. I would go this rout if yall have already checked the fusses and brake system itself out. Good luck
Old Jan 20, 2004 | 11:23 AM
roadrat's Avatar
Mine does that only in very cold weather, always resets just like his, not a problem when it gets milder. I think if only rear wheel abs sensor is on the rear diff, but if 4 wheel abs there are also two more sensors, 1 at each front wheel. kinda makes it a little harder to track down the culprit, but most of the problems seem to be with the rear one. From reading other posts i see that the speedo being slow to react, needle doesn't move until your speed is up to 10 or 20 mph, is another indication the sender is going south.
rob
Old Jan 20, 2004 | 01:28 PM
magnum's Avatar
The other thing to check would be if some foreign material, aka- mud, ice, whatever has gotten onto the tone ring. You will find the tone ring is what the wheel sensors monitor, looks like a slotted ring, located directly under the wheel sensor. If the tone ring has "teeth" missing from it, that would also cause your ABS light to come on.
PS to roadrat---mine has done that "cold" thing on two occasions, both were in the -20F range. About drove me nuts
fitzydog
21
Oct 11, 2017 12:09 PM
DodgeRam24V
0
Jan 7, 2012 06:02 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
