ABS reset?
ABS reset?
My previous post I replaced a split rear brake line & wheel cylinder. Bleeding was normal & the pedal came back. After this the ABS light & the brake light came on. Turns out that the switch on the ABS below the master cylinder was broken. I replaced it & plugged it back in. The lights still come on. I can short out the connector side of the switch & it resets the lights. If I plug it back on the switch the lights come back on. The brakes are fine. Dose the ABS need to be reset with an ABS meter? My OBD ll does not see an error. 96 RAM 2500 Thanks
fitzydog
21
10-11-2017 12:09 PM
sssmaly
07-13-2007 12:57 PM
mr T
02-24-2007 06:42 AM
