HELP! ABS code63-shuttle reset switch
My ABS light and brake light both come on when I get on the brakes pretty hard, and stays on until I turn the truck off. After re starting the truck the lights are both off until I get on the brakes again. I found a person with a scanner and the code came up 63-shuttle reset switch, but neither of us know where it is or what it does. Is this just a sensor switch problem or more involved? Any info on this would be greatly appreciated considering I have a heavy trailer I need to pull Monday
Code 63 is for the ABS.
Found on this site
http://www.wellsve.com/custom_search...oublecodes.php
– Rear Reset Switch Closed
Probable Cause[s]
1.Leak in hydraulic brake system
2.Faulty CAB
3.Faulty hydraulic control unit
Found on this site
Probable Cause[s]
2.Faulty CAB
Syndicate
16
Feb 15, 2009 05:36 PM
