ABS Light on.
Old 09-20-2011, 09:13 PM
birddoctor's Avatar
ABS Light on.
Coming home tonight,I noticed that my Brake and ABS light kept flashing on off.They would come on for a few seconds then go off.After I turned off the highway,I hit a small pothole in the road and this time they came on and stayed on.Anybody know why this would be going on???????
Old 09-20-2011, 09:19 PM
TOM R's Avatar
does the pump run after the truck is turned off?
if so the abs ecm is dead, it is about 170 with shipping both ways to repair ir 1200 for new installed be dealer
Old 09-21-2011, 07:51 AM
birddoctor's Avatar
No the pump doesnt run after its cut off.Brakes seemed to be fine.
Old 09-22-2011, 04:38 PM
birddoctor's Avatar
Found the problem.Left front wheel sensor intermittent.Now all I have to do is find a new one.
Old 09-23-2011, 07:38 AM
patdaly's Avatar
Rock Auto has them, one for high 60's, other high 70's.
Old 09-23-2011, 04:35 PM
Dieseldude4x4's Avatar
Do you have a four wheel drive? Good luck if so.
Old 09-23-2011, 04:41 PM
patdaly's Avatar
Rock Auto also has the 4X4, they were actually cheaper then the 2WD ones......
Old 09-23-2011, 07:11 PM
birddoctor's Avatar
No its 2 wheel drive.Thanks for the tip.Will look for one there.
Old 09-26-2011, 01:34 PM
No I meant for replacement. From what I can see if hte service manual, the whole hub has to come off of the 4x4's to repalce this sensor. That is why my light has been on for about nine years now.
fitzydog
21
10-11-2017 12:09 PM
Joey-D
12-12-2011 12:52 PM
BigBore050
03-09-2010 11:46 PM
sssmaly
07-13-2007 12:57 PM
mr T
02-24-2007 06:42 AM
Quick Reply: ABS Light on.
