98' 24 valve info..
Old 12-11-2003, 05:05 PM
Cummnzpowr's Avatar
98' 24 valve info..
???Do you guys have much info on bombing and reliability on the 98' 24 valve trucks? there's one for sale near me with 94,000 miles on it,4x4,quad cab,5-speed loaded for$16,500.Was wondering if this is a good truck to get..i want to move into the 24 valve truck real bad so i can learn more about it.http://www.autorevolution.com/dealer....cfm?vid=34135 <---here's the demo and pics of it,tell me what you all think,thanks...Greg ;D
Old 12-11-2003, 05:23 PM
barracuda's Avatar
Re:98' 24 valve info..
i got one and bombed it..i had to replace the VP after piercing the wire...no prob's other than that...
Old 12-11-2003, 05:26 PM
Cummnzpowr's Avatar
Barracuda: tell me about your pusher pump system,what brand?any problems with fuel pressure since? how are you running it? are you running it with your lift pump as well, or did u bypass it and run JUST the pusher?Thanks for the help
Old 12-11-2003, 05:46 PM
barracuda's Avatar
i ran it in-line w/ the factory LP, i ran it about half-way between the fuel tank and the LP...Mine is a pump off a 6.5 liter GM diesel ( my dad runs a fleet and and has a bunch of 6.5's in his smaller school buses )...i have a switch hooked up in the cab so i can turn it off momentarily when i start it up so it doesnt send too much pressure to the VP on initial start-up...pressures have been strong, no leaks, no prob's ( my dad sez these little pumps work for a long time for him so...) also, if the pump fails, fuel will run past it fairly easy versus some other pumps...works for me for now...my next upgrade will be the "max-flow" kit from wildcat, i like the idea behind it..
Old 12-11-2003, 09:46 PM
thumper 549's Avatar
I don't want to sound like the naaag here but the 1st couple of years have the worse problems ...just start looking at my prior threads starting about 2 mo ago ..if ya want to know more pm me
Old 12-11-2003, 10:21 PM
DTR Advertiser
Don M's Avatar
[quote author=Cummnzpowr link=board=4;threadid=23606;start=0#msg222235 date=1071183900]
[/quote]
If you sell your 12 valve for that 24 valve THING...I will kick you as hard as I can the next time I see you
Geesh.....I cant believe you would even think like that... :P
Don~
Old 12-11-2003, 10:25 PM
Dr. Evil's Avatar
I agree with the last 2 posts......Ive have heard of lots of problems with the first few years of the 24V....I work with a guy that went through 5 lift pump, and injector pump and eventually dropped a ring.....he had big trouble with his 98.5
Can I buy your 12V - Ive been looking to get rid of my 24 for a while....juts cant find the 12'er that I want....
Old 12-12-2003, 07:57 AM
barracuda's Avatar
yeah cummnzpowr, i love my truck but if i did my homework before hand i may have looked harder at a late model 12 valver, i always worry about pushing my pump too hard..i wish someone would just make a bullet-proof VP-44.. :
Old 12-13-2003, 04:02 PM
rich's Avatar
We,ve got two the wife truck gets the easy life. Mine on the other hand gets to work its tail off. A lot harder then probably any of these other guys do. its just like the one you described
i got it it with 147k on it from a guy who hauled cattle with it. its peirced and runs like a scared rabbit. the only things i have done is a lift pump and a clutch along with a rebuilt tranny due to prior maintence abuse their aint anything wrong with them. Any other questions give me a holler i'm just up the road from ya
Old 12-13-2003, 04:36 PM
Tiny's Avatar
I haven't BOBM'd mine the way some of the others have, but mine is solid as a rock. Had to replace a lift pump and a starter, other than that no engine problems at all. Get some 275s and a box, and have a blast.
Old 12-13-2003, 04:45 PM
AlpineRAM's Avatar
I've had good luck with mine.
Lift pump went bad (caught it fast enough)
Tranny went bad due to wrong fluid and overfill from the previous owner.
Now has 201000kms and has been bombed for the most of them.
The rest were either peanuts or caused by hitting or get hit by hard objects and rodents eating insulation. >
AlpineRAM
Old 12-13-2003, 05:24 PM
Cummnzpowr's Avatar
Thanks for the info gentlemen...but see signature for truck.Sorry had to part with the Gator.20% interest over the past year has killed me, i got a screaming deal on the new one.Now running real fast from Don M.<--- :-*
Old 12-13-2003, 05:36 PM
MYTRNx3's Avatar
Don M --- common now! You drove in my truck and didn't have anything bad to say about it!
Greg- knew you'd come around sooner or later! :-* :-* :-*
donhov
10-12-2007 11:44 AM
tboling
04-09-2007 09:04 PM
scottrod
01-21-2004 06:51 PM
FireNhole
03-14-2003 04:56 PM
Quick Reply: 98' 24 valve info..
