97,12 valve more power
Old 02-21-2007, 07:53 PM
Chris Sublett's Avatar
I have a 1997 3500 12-valve that I have had for 8 years. About 7 years ago I put a number 11 TST plate and boost elbow with guages in.At that time it seemed to be a major improvement, but now I want more power.
The truck has a little over 200,000 miles on it and still runs fine. I have a couple of questions? 1, what are the options for upping the hp to around 350?
2, what clutch/pressure plate will work with that hp range?
This truck is not driven daily but when it is it usually has anywere from 11,000 to 20,000 lbs behind it. With the setup I have now I have never been able to get the temp on the pyro above 1150 degrees with max boost at 34 lbs. I have been told that the temp should get up to 1350 with the setup I have. I relize that 1350 is meltdown but I cannot make it get any hotter. I pulled Jelico mountain with 20,000 lbs on the trailer and around 1150 deg was max in 5 gear on the floor. Also my temp guage is installed in the elhaust manifold pre-turbo.
I am a new guy to the page any info will be greatly appreciated, Thanks Chris Sublett in Ky
Old 02-21-2007, 08:13 PM
mainer's Avatar
i'd put a 3k govenor spring in it.... can do this for like 50 cents using washers, gives it a noticeable ammount down low, revs quicker, responds faster
can also grind your plate to a #10, this should help some....
your not reallly going to be able to get 350whp on stock turbo and still be able to tow as heavy as you do without having problems with temps..
maybe some 300hp injectors.... but its gonna get hot quickly on stock charger
Old 02-21-2007, 09:56 PM
displacedtexan's Avatar
You will need a turbo as mentioned, and as far as clutches, South Bend is the most popular by far, but Valair is a company in Texas that has been around a while and is starting to make a name for themselves as building a good clutch for noticeably less than a lot of the others out there.
To get more power out of your truck the first and foremost investment is a good set of gauges. These are a must anytime that you are adding more fuel to your mix. At the very least a Pyro, a boost gauge is really nice to have, and if you have an auto, a tranny temperature gauge as well.
A governor spring kit, referred to as a GSK is a wonderful investment that widens your normally narrow power band from the 12 valve engine and allows you to fuel hard to at least 3200 RPMS or so, before it starts to defuel, this is all dependant on your governor arm adjustment and your plate positioning.
A Torque, or fuel plate should come next. NO one really follows the plate guide anymore and the most popular plates nowadays are 100, 10 and a zero plate
More commonly referred to as fuel plates, they come in different numbers to explain how "aggressive" (for lack of a better term at the moment) that they are 11, 10, 8, 6, 5, 0, and 100, zero being a flat plate that bombards the pump with fuel, and a 100 being a ten plate curve with no top end defueling, much like the zero.. The plate goes in the P7100 injector pump, It goes under what is called the AFC housing, which has a little starwheel on it, the starwheel can be accessed with the removal of the hex dealy using the the right hex head size plug, and you loosen it for more smoke, and better lower end, and tighten it for the inverse. Use a good screwdriver.... furthermore... You will see four screws there where the starwheel is, two that are flat, one that is possibly a breakoff screw that can be a real pain to remove, take a hammer and good screwdriver and bang the tar outta it, it will come off, if that fails, left hand drill bit... Looking down the driver side, the top left hand is the breakaway, and the top right is a regular screw as well, the bottom two are 8mm bolts and you need to get around to one that is in the back of the AFC housing that holds that fuel shutdown solenoid in place...
The other tricky bolt is the one (if you look down from the drivers side) behind the Fuel shutdown solenoid (electronic hooked up deal that bolts in front of the injector pump, easily removed with in my case an 8mm (and most should be too) socket and pull out the two bolts. when you undo those you will notice that there is one in the back that is holding the housing, you can just loosen the one in the rear using a deep 8 mm socket and just move the shutdown solenoid out of the way, (downward) and then you can get to the plate..
When you are in there its simple, you just remove the stock plate and put the other plate in place of that one. NOTICE you have some play here. Sliding it forward of the stock position will net you more power, sliding it back will reduce the power.
Now put it back together and you are done. Installation is simply the reverse of removing it. Having a magnetic tip screwdriver REALLY HELPS. As you are putting the AFC housing back on you will notice that you can also slide it forward and backwards a bit as well, sliding it forward increases the low end fueling as well.
To increase the boost you will usually have to plug the wastegate line, it is the one that goes to the wastegate from the back of the AFC housing, you can get a boost elbow from many different vendors to increase the boost, or some just disconnect the line and plug it by clamping a screw in the end of the hose to keep anything from going in the hose.
Install time, for a newbie, well it will take you about a couple of hours at most. Your only real problem might be that break off screw, especially if your truck is stock, However, nothing a good strong screwdriver and some persuasion cannot take care of.
Which plate is right for you? A 10 is generally considered the best all around plate, many guys run a 100 for a little more to end, and guys that drag race and such tend to like the really heavy low end fueling of the zero plate.
There is no one setup that works for everyone, you may have to make some adjustments to the plate, AFC position, or starwheel to get it set to your liking and needs as far as power, responsiveness, and smoke.
Either ways, you are going to need a clutch or tranny work if its an auto. And your EGTs will tell you when you need an intake and exhaust to help keep the temps down. Neither of them will gain you power alone, but they can help you get more from the fuel that you already have.
The next step is usually advancing the timing, which requires more advanced skills, and special tools.
dieselJon
07-22-2007 12:39 AM
tony597fitter
12-18-2006 04:31 PM
robox
10-18-2005 07:38 PM
j
12-21-2003 10:26 AM
Quick Reply: 97,12 valve more power
