77 windshield into a 92
Old Nov 13, 2008 | 04:33 PM
taterfarm's Avatar
I've got a 77 windshield, will it fit my 92 or is it different?
Old Nov 13, 2008 | 05:15 PM
Bigone721's Avatar
It'll fit, all the cabs are the same from '73 to '93. The windshield in my '91 is from a 70's truck.
Old Nov 13, 2008 | 05:56 PM
taterfarm's Avatar
good
thanks
Old Nov 13, 2008 | 07:27 PM
ccab85's Avatar
part numbers changed sometime in the later years but all should fit.
Old Nov 13, 2008 | 10:00 PM
Richie O's Avatar
366 Spring Chicken
Tator, I just put one in my project 93 and they came to the house and installed it for 190.00. They gave me a lifetime leak guarentee. Its a tinted one too. It was Dirigo Glass out of Belfast. I think they said 180 if I went to the shop. Its 45 min travel for you but just a thought.
Old Nov 13, 2008 | 11:31 PM
taterfarm's Avatar
Well now I am going to have to take a close look at the 77 windshield and make sure it is in great shape.
Maybe I will see how easy it comes out and if I shatter it then I will go there and have it done. I would like to have the tinted part too and its going to be a pain to try to tint it myself.
Old Nov 13, 2008 | 11:36 PM
HappyCamper's Avatar
If you are concerned about shattering the glass, consider cutting it out and then purchasing a new rubber grommet for installation. When I had my window replaced a couple years ago the new grommet was about $20 (USD)
Just a thought
Old Nov 13, 2008 | 11:50 PM
Alwaysworking's Avatar
alwaysonDTR
to get them out it is easier to cut the gasket if you are useing the windsheild if the window is bad kick it out and reuse the gasket, mine was about 64 dollors if i remember right
Old Nov 14, 2008 | 05:09 AM
Jim Lane's Avatar
Might also want to check and see how bad it is pitted before you go through all the trouble.
Every time I tried to reinstall used glass it would delaminate at the edge or it would shatter when I was almost finished.
The guys at the glass shop make it look so easy when they install one but like anything else it is a skill you only gain by breaking some glass.
I used to replace glass on transit coaches probably two a month but it was at least 3/8 thick and if it cracked and there was still a big piece left then the glass man would cut it into a smaller window glass then the scraps went into the trash can.
Jim
Old Nov 14, 2008 | 07:55 AM
archer2's Avatar
These guys have the gasket for $4.45 (four dollars) plus shipping (I don't know how good it is, it's made in Taiwan. I ordered it just because) It doesn't come with the lock strip so you either need that or reuse yours. My glass guy says none of his suppliers have the lock strip right now.
http://shop.carbodyparts.net/search....&part_subtype=
Old Nov 14, 2008 | 08:16 AM
RSWORDS's Avatar
Should fit... If not throw a brick at it and only glue the pieces you need back together.
Old Nov 16, 2008 | 09:44 AM
samiam4's Avatar
The $4 doesn't mention anything about a locking strip. The more expensive one does. The previous page has locking strip- $37.
KATOOM
15
Apr 14, 2003 02:21 PM
Dieseldude4x4
Mar 16, 2003 10:00 PM
BigBlue
Mar 15, 2003 06:48 PM
WA4SLC
Feb 10, 2003 04:54 PM
Holsteinman
Feb 5, 2003 09:26 PM
