53 block
Old 04-30-2004, 05:37 PM
doug60's Avatar
53 block
Did any one ever get anywhere with the cracked block issue. my 96 is suffering from it. I also had the timeing cover issue about two years ago. Just bought a new one I hope its not plagued with problems.
Old 04-30-2004, 09:29 PM
Haulin_in_Dixie's Avatar
How did your '96 get a #53 block? Are you sure it is a #53?
Old 05-01-2004, 06:27 AM
doug60's Avatar
I will have to check the numbers but I definetly have the cracks!
Old 05-01-2004, 06:44 AM
doug60's Avatar
These are my numbers Engine number 56262457
REF. NO. 53040138
Old 05-01-2004, 08:46 AM
kandgo's Avatar
The number 53 is cast on the passenger side of the block above the oil pan, are you sure you don't have freeze plugs leaking?? As this was only in 98,99 and rare 00's
Goodluck,,,Rick
Old 05-01-2004, 11:06 PM
VPI
VPI's Avatar
Is the 53 block something you need to worry about on a 12v early 98. I am considering purchasing one. Thanks
Old 05-02-2004, 06:53 PM
doug60's Avatar
Its not the freeze out plug I can see the crack
Old 05-03-2004, 01:21 AM
Doug does your block have a #53 on it?
Old 05-03-2004, 04:07 PM
doug60's Avatar
I dont know but its raining out,so I cant go look.
Old 05-03-2004, 10:01 PM
INJECTOR JACK's Avatar
Question cracked?
Just wondering were the block is cracked? This is realy uncommon. Did it freeze up?
Old 05-04-2004, 08:00 AM
RCW
RCW's Avatar
Cracking on 12 valve blocks is not at all uncommon. In fact, it is becoming more common all the time as these engines age. What happens is the original coolant recommendations from Cummins did not take cavitation into account, as it was originally believed that blocks with cast-in cylinders did not have the problem. Cummins has upgraded their coolant recommendations to include use of anti-cavitation products last year.
I recommend following Cummins latest cooling system maintenance procedures and then either running BarsLeak in with the coolant, or switching to Evans Cool to prevent the problem. Evans Cool is the best preventative, but much more expensive.
Anyway, what happens is the lower side of the casting, where the cylinders join the web that supports the skirt, will crack through from cavitation related corrosion.
It is repairable with the new alloy welding rods now available. I posted the procedure on another forum, but if someone wants it PM me.
Old 05-04-2004, 01:55 PM
Ok but this is not a stress related crack like the #53 blocks have is it?
Old 05-04-2004, 09:03 PM
Rattletrap1's Avatar
Cavitation shouldn't cause corrosion...but erosion. Same result.
In my '83 Ford I ran Penray Pencool 3000 additive.
Old 05-06-2004, 09:24 PM
mattgbank's Avatar
How about useing the ford motorcraft additive they sell at napa? Thats what i used to use in my 7.3.
thanks, matt
Old 05-07-2004, 08:54 AM
jrs_dodge_diesel's Avatar
I believe that additive is FW16 coolant addative.
Bubspc
07-27-2007 10:32 PM
24Vford
01-02-2007 11:14 AM
plow
12-28-2005 02:42 PM
1320
05-17-2003 03:28 PM
Quick Reply: 53 block
