will 51" donaldson muffler fit?
Old 07-22-2010, 03:58 PM
Doj Dewd's Avatar
i have a 2000 auto 4x4 short box with 4" TBE on right now. i just replaced my turbo and needed a hx40 DP. now my exhaust has a rather large gap in it and i need to fix it up. instead of just putting pipe up there to fill the gap, i was thinking of going to big donaldson muffler and eliminating the mbrp muffler.
anyone know if this will fit under the truck without contacting any other metal?
https://dynamic.donaldson.com/webc/W...210&item=22264
i have searched and came up with a lot of 3rd gen threads, but couldn't find anything on 2nd gens . . .
Old 07-23-2010, 08:39 AM
cmed250f's Avatar
probably should just get rid of the mbrp skip the donaldson and throw a straight pipe up there and let er bark.....it seems to be most logical haha
Old 07-23-2010, 10:48 AM
Doj Dewd's Avatar
the whole point of even thinking about a donaldson is to quiet it down. straight pipe is out of the question - just not my cup of tea for a DD truck.
Old 07-23-2010, 01:09 PM
gloverb's Avatar
muffler
i think that is what I have. It is 4" in and 5"out. It is tight but fits. You can look at mine if you want.
Old 07-23-2010, 01:28 PM
Doj Dewd's Avatar
the specs say 4" in/out.
where are you at? if you are close i might have to drop by . . .
Old 07-23-2010, 01:29 PM
Doj Dewd's Avatar
gloverb -
how do you like it sound/performance wise??
Old 07-24-2010, 04:08 PM
LongBlackRam's Avatar
I have had the 51" Donaldson muffler installed for several years now. There is plenty of room. I like the way it quieted down the truck compared to the Magnaflow muffler.
You can see the Donaldson hanging slightly below the frame, but so does the fuel tank.
Old 07-28-2010, 12:18 AM
Doj Dewd's Avatar
you have a long box it looks like . . . do you forsee any problems on a short box?
did you retain the baffles, or knock them out?
Old 07-29-2010, 07:14 AM
huck25's Avatar
I have a short box with stacks and I made mine fit. Not alot of extra room but I did get it in there. I would take some pics for you but some young punks broke into my truck and stole my camera.
Old 07-29-2010, 01:22 PM
I don't have access to a short box to look at. I suggest you get the measurements for the muffler and check the fit because the fit is going to be tight. My installation has the muffler mounted to the rear so that the tail pipe is attached to the muffler's exit. The front of the muffler is just aft of the transfercase. Doesn't look like a good idea to try and fit the muffler between the transfercase and frame because they would be too close.
I left the baffle in.
I hope this helps.
PK
Old 07-29-2010, 01:36 PM
Doj Dewd's Avatar
i have taken a tape to the truck and it looks like i'll hae to do the same - mount the muffler as far rearward as i can, like you said, the transfer case looks like it may get in the way. if it does get in the way, i could always heat up and bend the outter shell of the muffler to clear the case.
thanx for the help/info . . .
Old 07-29-2010, 06:58 PM
Why not see if Donaldson or Nelson make a similar muffler that is shorter than the 51". To me that would be better than modifying the airflow through the muffler and giving the transfer case the extra heat.
PK
Old 08-02-2010, 08:58 PM
gloverb's Avatar
I live in the S.E. of Calgary. I had a straight pipe for a while before I put in the Donaldson. It is a lot quiter now.
Old 08-03-2010, 01:34 AM
Doj Dewd's Avatar
maybe i could meet up with you and have a look. care to PM some contact info . . .
Jbremount
0
09-08-2014 01:05 AM
CalypsoCowboy
08-20-2008 07:11 PM
PEAKSTRYDE
10-11-2007 04:20 PM
gipsl67
08-22-2005 11:58 PM
coolslice
33
11-25-2004 12:37 PM
Quick Reply: will 51" donaldson muffler fit?
