500 hp and stock lines
Old 10-20-2006, 12:01 PM
OldSmokey's Avatar
Im looking to run about 500 hp or so, with a TST MP-8 stack and water meth. With all supporting mods. The question that I have is with the jacobs brake that I have the vacume pump is in the way of a big line kit. So if i drill the banjo bolts and use the stock lines from the fuel filter will there be enough fuel without using the big line kit. Thanks Joel
Old 10-20-2006, 12:08 PM
wheelndealn's Avatar
How is a exhuast brake in the way of the fuel system?
Old 10-20-2006, 01:00 PM
OldSmokey's Avatar
Its not the break its the vacume pump that sits right buy the CP3. It sits so close that the big line kit wont fit. I called glacier diesel and they said that you just need to install a high flow banjo. There is a pic in my profile.
Old 10-20-2006, 01:20 PM
DTR Advertiser
Timinva's Avatar
My lines from the filter to the cp3 are stock. I have a customer with a 06 and his fuel system is stock front to back and he is running 540hp and 12.60s. You will be fine at 500hp. Tim
Old 10-20-2006, 04:27 PM
wap
wap's Avatar
Do not know if there is any truth to it but I have been told the big line kit is a waste of $ with a stock cp3, but I could be wrong, just a thought
Old 10-20-2006, 04:41 PM
Speed Shift's Avatar
The stock lines will do the job, a pusher pump will feed the CP3, after that worry about draining the rail. If you move to a geared up CP3 or staged CP3 you can worry about different size hose, untill then forget about it.
Old 10-20-2006, 05:52 PM
OldSmokey's Avatar
Thanks thats just what I was wondering. Im planning on a walbro kit to supply the fuel.
Old 10-20-2006, 06:01 PM
2broke2smoke's Avatar
does the 540 horse '06 still have the in tank pump?
MrKen
02-25-2005 04:22 AM
yannick
04-26-2004 03:38 PM
hellotbone
09-01-2003 08:46 PM
Hummin Cummins
02-11-2003 12:14 PM
Quick Reply: 500 hp and stock lines
