5 gal. airtank...Where to put it?
Old 06-01-2008, 01:53 AM
twoforme2's Avatar
I am adding On Board Air to the truck, to run exhaust brake, air bags and etc. (read big air horns). But where oh where can I get this 5gal tank mounted on the truck, I have crawled all around under it and cannot find a suitable spot.
Truck is 2007 QC 4x4...any ideas?
Old 06-01-2008, 07:21 AM
mikmaze's Avatar
does it fit between body and frame rail under the bed of the truck ? that was where I was going to put mine but I measured wrong on my 8.5 gallon tank and ended up with a spare tire in the bed and the tank where the spare was.
Old 06-01-2008, 09:05 AM
twoforme2's Avatar
No it is too big to go there. I was trying to avoid a toolbox in the back, but it is looking like it may come to that
Old 06-01-2008, 09:07 AM
Roperteacher's Avatar
I may sound dumb here ,but what size is the Air tank that comes with the Pacbrake? THey mounted mine behind my front Drivers side headlight. Probably not as big as yours However..... I opted to put my spare tire in the bed of my truck as I figured it would be easier to get at in the middle of nowhere pulling my trailer. It's chained to my gooseneck hitch! Much eaier to change diff fluid as well.
Old 06-01-2008, 09:11 AM
twoforme2's Avatar
I believe the pacbrake tank is only 1/2 gal.
Old 06-01-2008, 09:37 AM
Raspy's Avatar
I haven't installed mine yet but I made room next to the fuel tank when I ran the exhaust out the side. By turning it out in front of the rear wheel I opened up a large space. Perfect for a five gallon tank and now I have 5 feet less of exhaust piping under there too. I was able to modify my existing 4 inch MBRP stainless system without any tube bending, just some cutting and welding.
John
Old 06-01-2008, 12:56 PM
cbrahs's Avatar
is your truck lifted with bigger tires? Since i have 37's on mine and can't use the spare, that is where both of my 9 gallon tanks went.
Old 06-01-2008, 02:13 PM
rbertalotto's Avatar
In my "Sand Dune Riding" days we used to build tubular bumpers, weld them up good out of thick walled pipe and use them as an air tank.
You could also use your spare tire as an air tank, as long as you have an onboard compressor, this will work slick as moose sh--!
Old 06-01-2008, 02:58 PM
Gary Emerald's Avatar
what are the dimensions of your 5gal tank? I've got a 10gal tank mounted between the bedside and the frame rail on the driver's side of my '98. I haven't looked under my '04, but I've got to assume a 5gal tank will fit
Old 06-02-2008, 01:29 AM
twoforme2's Avatar
No truck is not lifted and I have no plans to do so anytime soon, I already have a height issue with it and my 5th wheel.
As for dimensions of the tank, right now I am a couple hours away from home and will be so for a couple weeks it looks like right now, so going out to the garage and taking a measurement is a little tough.
I did slip it up over the rear axle and it left about 4-6 inches of room there between it and the axle, but I was too worried about putting it there.
Between the bedside and frame rail wont work, it is too long and/or too fat...I don't remember which one.(I know I attempted to put it there, but it would not fit)
So I guess the options are to find a smaller diameter tank (or a couple of them), buy a tool box to put it in, or buy a sliding tonneau.
barngal6
07-05-2009 06:49 PM
ed cloud
08-21-2004 01:53 AM
Rusty69
03-26-2004 06:15 PM
Lightman
29
03-08-2004 12:10 PM
NWDave
05-02-2003 11:55 PM
Quick Reply: 5 gal. airtank...Where to put it?
