4wd light question
Old 08-28-2011, 11:06 AM
kennyblatz's Avatar
4wd light question
when my truck is in 2wd the 4wd light is on and comes off when i pull it into 4wd. any ideas
thanks
Old 08-28-2011, 12:05 PM
Tallguy67's Avatar
That is rather odd. If your 98.5 is that same as my 2000, then that is just about the simplest circuit in the whole darn truck. When I was troubleshooting mine a year ago, I popped the wires and boot of the switch on the CAD. I jumpered the two connectors in the boot on the light came on, removed jumper and light went on (obviously with truck turned to run so there was power to the dash). the only other thing in the circuit is the contact switch. The contact switch is easy to remove from the CAD. You MIGHT lose a little oil if you pull the switch. If it were me, I would test the wiring like I mentioned first, then pull the contact switch and test it with a test light or ohm meter.
Hey - I just had a thought that some others can weigh in on - if you connected the vacuum lines to the CAD backwards, would the CAD operate backwards???? Would it lock the CAD when t-case was in 2wd and unlock CAD when t-case was in 4wd????
Old 08-28-2011, 05:49 PM
KATOOM's Avatar
Sounds like the vacuum lines to the CAD are backwards.
Old 08-28-2011, 05:58 PM
kennyblatz's Avatar
yes they were thanks
Old 08-28-2011, 05:59 PM
maxwellp's Avatar
Talking
What he said yes, I did that to mine when I replaced all the lines. Just flip the two around.
Old 08-28-2011, 09:39 PM
Tallguy67's Avatar
See, I am not so stoopid after all. As a wise man once told me 'Even a blind squirrel finds a nut know and then'.
p0wd3rp1l0t
06-27-2012 10:29 PM
wrangler04
07-17-2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
12-29-2006 07:17 PM
95black2615
12-20-2006 06:37 PM
1320
05-06-2003 06:30 PM
Quick Reply: 4wd light question
