4WD light out in dash but 4WD still works
Old 09-27-2011, 06:07 PM
p0wd3rp1l0t's Avatar
i have the on the floor shifter in my 06 and when i shift into 4wd high or low my 4wd light in the dash does not come on. it stopped working last winter and i am just wondering wat could be the problem...any ideas?
Old 09-29-2011, 12:51 AM
Zeus1987's Avatar
same thing happened to mine. I'm guessing the bulb in the cluster is out. Not sure how hard it is to change
Old 10-02-2011, 11:40 PM
well give me a couple weeks and i will find out...i gotta put a set of heater treater doors in my truck so i think most if not all the dash will be out and i will check it then
Old 10-03-2011, 09:47 PM
VP_07SRT8's Avatar
whats heater treater door?
Timmytorco (04-23-2023)
Old 11-04-2011, 10:47 PM
Reelay's Avatar
Before pulling the cluster panel off check the bulb by pushing in the trip meter with the ignition switch off then turn on the ignition and let go of the trip meter all lights should light up if the 4 wheel light does not then the bulb is burned out if it lights up then you probably have a faulty sensor in the transfer case. Easy fix just remove the sensor and replace.
Old 06-27-2012, 09:40 PM
heater treater doors are replacement doors/flaps in the dash that direct air to feet/defrost/vents. they are made of metal and alot stronger and dont break like the stock ones do
Old 06-27-2012, 09:54 PM
where is the sensor? is it on the transfer case somewhere?
Old 06-27-2012, 10:29 PM
Reelay's Avatar
In my 06 it is located on top of the transfer case on the drivers side easy to get to. Several wires going into it that unplug which have a little catch you have to release. Check the continuity with a meter after you unplug the wires. I got my sensor at a local dealer can't remember the cost but not too much but parts are always more from a dealer.
NoSparkplugs
17
05-17-2009 10:36 PM
mar67655
02-08-2009 05:15 PM
wcbcruzer
09-05-2008 08:36 AM
abc4yew
03-29-2008 08:37 AM
Txwelder
01-30-2008 09:32 PM
Quick Reply: 4WD light out in dash but 4WD still works
