47re valve body in a 48re trans
does anyone know if this will work or not,im having nasty 1-2 shuttle problems on med. throttle and i have a 47 re valve body layin around and wanted to swap it out just to see if it fixed my problem.
Location: In Oroville, Ca., same house for past 46 yrs!
yea, it should be fine for the test.
hey, do you have any front wheels and tires for a dragster? like the 2-1/2" wide x 17 ones?
We have a T/D too and it's getting some new panels and paint along with a few other goodies and those are on my list.
05' has the electronic TV cable and it will not work correctly with the 47re VB. If you want to address the shuttle shift get a DTT shift enhancer or similar product.
If the VB is setup correctly it should work fine. There are some minor differences in how the VB does its job that might cause problems but its not a given. Some of the builders actually like the earlier VB's as they say they are easier to get to function correctly.
i did fix the problem by removing the sonax tv valve and putting the stock one back in< i have instaled hundreds of the sonax valves and never had this problem.but hry,theres a first for everything.
Bersaglieri
22
11-05-2007 11:30 PM
