45 psi?
Old 11-21-2008, 12:22 AM
cstmfabman's Avatar
45 psi?
I was looking at this lift pump http://www.dieselsite.com/index.asp?...ROD&ProdID=475 Is it too much for the injection pump, or will it simply bypass the extra pressure back to the fuel tank?
Old 11-21-2008, 12:34 AM
Zeus1987's Avatar
if im correct it is too much. dont think you should have more than 20~
Old 11-21-2008, 07:51 AM
j-fox's Avatar
Use it with a regulator set at 14 psi. It will last forever because it is loafing.
Old 11-21-2008, 06:02 PM
bent valves's Avatar
I have been running this pump for 5 or 6 years. It is designed for operation with diesel and uses a stainless steel pump mechanism. It is rated for 40 psi but will easily top 100 psi. A bypass regulator will be required. It uses the diesel fuel flowing through it for cooling.
It is a good idea to use a resilient mount when bolting to the frame. It can be loud. Also don’t skimp on hose size. This pump moves fuel and must have a -10 AN pick up tube (5/8”).
I use a circuit to slow the pump down to limit the pressure but that is another story. If interested, search for PWM pump controller on this site.
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
Quick Reply: 45 psi?
