3rd gen stock turbo swap ???s
Old 01-17-2008, 07:51 PM
smkn97s's Avatar
Ive been thinking about swaping a 3rd gen turbo on my 97 12valve, It seems like they should be better than my hx35 but im not an expert on these turbos. Ive been looking around and the ones that ive seen have some electronic plug on the compressor what is it for? Are the oil feed and return the same style? So is it worth swapping
Any help would be great!
Old 01-17-2008, 07:55 PM
Big Blue24's Avatar
I noticed that the flange is not divided on the 04.5-06 electronically controlled wastegated turbos. I don't know how much it would affect spoolup.
Old 01-17-2008, 09:06 PM
mopar-or-no-car's Avatar
https://www.dieseltruckresource.com/...d.php?t=181022
Old 01-18-2008, 09:33 AM
smkn97s's Avatar
Does anyone know if a 03-04 turbo is the same as 04.5-06 other than the electronics for the waste gate?
Old 01-18-2008, 10:15 AM
Dwitt0187's Avatar
no it is a differant turbo the 03-04 turbos have a mechanical wastgate on them unlike the 04.5-07 have electronic wastgates
Old 01-18-2008, 09:31 PM
smkn97s's Avatar
Whats size is the compressor and exhaust wheel.
Old 06-02-2008, 03:02 PM
Big Blue24's Avatar
04.5-early 07' HE351cw turbo 60mm compressor, 60mm exhaust turbine wheel, 9cm open throat turbine housing.
Old 06-02-2008, 03:10 PM
Don Wagner's Avatar
I'm working on a modified HE351, it will have a 2nd Gen HY35 cover, mechanical wastegate, 1" wastegate volute, and the turbine wheel will be clipped 10°. All HY35 versions have an undivided inlet.
Old 06-02-2008, 03:15 PM
Big Blue24's Avatar
Don, did you notice that the HE351cw has a 2mm larger turbine wheel? I'm sure you could/can machine that much no problem. Does the 10 degree clipped wheel flow better on the topend?
Old 06-02-2008, 04:24 PM
Don Wagner's Avatar
I will mic the difference between the HE341 and HE351. The clip on the turbine is equal to opening up the turbine AR ratio helping the overall flow of the turbine wheel.
Old 06-03-2008, 01:01 PM
turboguy121's Avatar
i dont think that your housing from the hy35 will work its a lil bigger than the bearing housing on a HE351.
Old 06-03-2008, 01:06 PM
Don Wagner's Avatar
I'm not worried, I might know how to solve that problem. The inducer bore needs to be opened up and the surge pocket will probably be opened up 0.010" also.
anonymous_1
13
04-30-2020 04:29 PM
kammak
12-14-2007 08:48 PM
1qckdodge
03-05-2007 09:53 AM
ARAcummins
02-11-2003 08:41 PM
Quick Reply: 3rd gen stock turbo swap ???s
