3rd gen rear axle in 2nd gen?
Old 12-10-2008, 10:27 PM
8mpg's Avatar
Will a rear end from a 3rd gen bolt in? Im not sure if the leaf springs are spaced the same...anyone know?
Old 12-11-2008, 02:51 PM
tx_2500's Avatar
I may not be entirley correct, but I think the 3rd gen axles are wider by a couple inches.
Old 12-11-2008, 04:33 PM
patdaly's Avatar
They are also made by AAM, not Dana. I am not sure of the dimensions either.
Old 12-11-2008, 09:32 PM
J.Suplanski's Avatar
Talking Aam
Would not get rid of your Dana's! The AAM"s are not to good, twist and bend to easy! Grumpy John 4X4
Old 12-11-2008, 10:26 PM
dodgeguy71's Avatar
Yeah, I second the "don't loose your Dana".
Old 12-12-2008, 06:47 PM
atc250r's Avatar
I third that!!
Dana>AAM
Old 12-13-2008, 11:06 AM
8mpg's Avatar
I dont have a rear end on the truck to begin with...thats the problem. Found a couple low mile 3rd gen ones for cheap. A dually axle for a 2nd gen is $800+ where I can get a 3rd gen srw for $250.
This is an old 69 chevy truck project going on a 2nd gen Dodge frame.
Old 12-14-2008, 06:46 PM
Stamey's Avatar
Go with the 3rd gen. If you don't, I'll trade you my 2001 D70 for a 3rd gen AAM. Guys I have talked to that sled pull, and hear about my D70 woes on the sled track told me to get an AAM to put in it.
Chris
Old 12-14-2008, 08:29 PM
8mpg's Avatar
Chris
Does it bolt right in or does the leaf spring perches have to be cut off and rewelded?
Tim
Old 12-15-2008, 08:36 AM
atc250r's Avatar
You're best bet is to measure the outside to outside width of your stock springs and then ask one of the guys in the 3rd gen forum to take a minute to do the same. Heck, you could probably go down to the local Dodge dealer and measure one up.
John
anonymous_1
13
04-30-2020 04:29 PM
BRUISER
02-02-2015 11:25 AM
webby
07-23-2014 11:08 AM
ramsport59
10-29-2008 05:36 PM
patdaly
06-26-2007 07:38 AM
Quick Reply: 3rd gen rear axle in 2nd gen?
