37 no lift ?
Old 07-20-2009, 06:20 PM
Ridgetop's Avatar
37 no lift ?
Any thoughts or Ideas appreciated. If I take it easy will I be ok with 37x12.5 hankook mts for about a week untill my lift shows up. Tires I have right now are getting pretty bad. A little rub on the control arms doesnt bother me I just dont want to tear out the inside of my fenderwells. 37s are on the rear already. Thanx Phil
Old 07-20-2009, 08:30 PM
Ram Daddy's Avatar
Wink
so...you`re running 37s in the rear , and stockers up front right now
they`ll fit (on stock wheels)for limited street use , but if you`re only talking about waiting a week , for the lift to be installed , I`d just wait
Old 07-21-2009, 03:53 AM
Ridgetop's Avatar
37s in the rear 35s up front. Two wheel drive only. The tires are an hour drive south. The leveling kit an hour north. I know I should have had the leveling kit shipped to my house. The L kit will be in on Wed. My 6'' Revtek on Fri. Thinkin bout canceling the leveling kit but I dont want to have to be in a rush to install the 6" system. And yes they are on stock 17" aluminum wheels. Front tires are getting dangerously bald. Phil
Old 07-21-2009, 04:52 PM
Floridacracker's Avatar
Well try swaping the rear with the front. If it works it works
Old 07-21-2009, 07:39 PM
poindexter1's Avatar
I did try and they rubbed real bad didnt even drive it soon as i drop down there is only minimal clearance clarence
Old 07-21-2009, 08:39 PM
Administrator/Jarhead
madhat's Avatar
I run 35x12.50 BFG MT's. They rub a little in the front, not enough to have a problem.
37's would be too much with out some aftermarket rims or some spacers.
Old 07-22-2009, 07:20 PM
stock rims will clear much better than most aftermarket rims
but they would only rub the control arms.
Old 07-23-2009, 04:39 PM
Skyd Ram's Avatar
You will have a better chance clearing the 37's without a level spacer. When you run a spacer with the factory control arms it move the axle back a bit which increases the chance that your tires will hit the back of the fender. Especially on the passenger side since you wil be shifting your axle a little bit to the drivers side,
Old 07-24-2009, 09:13 AM
silverrhino's Avatar
I have 37x13.50r17 on stockers with a 3" kore kit. I had to trim the plastic inner fender and the corner of the pinch weld. It does rub the control arm but nothing terrible. I believe somebody on here had 37 bfg mt's on with a 2" leveling kit. I believe he did the same thing. I would say if your not driving much just take out the plastic inner fenders for the week.
Old 07-25-2009, 12:34 PM
Ridgetop's Avatar
Had the 37s installed last night. Pretty tight fit. Dont thgink Ill be drivin it much untill I put the lift on.
Txwelder
12-18-2023 02:35 PM
doomgaze
04-13-2006 01:21 PM
0425004x4
16
01-23-2006 06:43 PM
Txwelder
05-19-2005 06:10 PM
lucey
04-21-2005 09:53 PM
Quick Reply: 37 no lift ?
