366 spring
Old May 14, 2008 | 09:54 PM
dieseljoe92's Avatar
366 spring
just got my 366 spring and when i hold it in second gear and put it to the floor when it winds up it smokes like a train i dont know if that is good or not im wait in on gauges to check egts. should my truck do this or did i screw up something
Old May 14, 2008 | 10:09 PM
Richie O's Avatar
366 Spring Chicken
Get a gauge. You might be hotter then you think.
Old May 15, 2008 | 06:01 PM
What color smoke?
Old May 15, 2008 | 09:52 PM
black a lot of black
Old May 16, 2008 | 12:20 AM
Tron's Avatar
Before I put mine in it would barely smoke at wide open. After I put it in with the same settings I would stop traffic because of the smoke. It would make a cloud that would travel a city block and egt's could of hit 1500deg.
Point being be careful and get a pyro I recommend backing out the full power screw untill you have a haze at wide open. Mine also has the 16cfm housing so I can build a bit more boost than you to help cool egt's and those egt's are what I saw until I turned it down a bit. Thing is after you turn it down to manageable egt's you will still have gained power and also a longer power ban.
Hope this helps
BurrisWill
Jan 25, 2009 08:23 PM
KRB
Nov 27, 2007 03:34 AM
b1eric
Jun 12, 2007 08:46 PM
Mike T.
Feb 3, 2007 07:19 PM
vinny
Nov 15, 2005 10:55 AM
