will 307 gears with getrag 5 speed work ?
Old Feb 3, 2007 | 03:07 PM
diesel fuel's Avatar
Hi ... I cant make up my mind if I sould swap my 410 gears with 307 gears . I do most of my driving in the foothills and the 410's are great . But when I get on the freeway I am looking for another gear or two . Would the 307's be to high and cause to much heat for the getrag ? Thanks for your inf. ( AND How do you add to my discription on what I have added to my truck like you all have done ...new member here Thanks
Old Feb 3, 2007 | 03:20 PM
haloman's Avatar
To add a signature go to user cp and click edit signature. 3.07's with a getrag are awesome but it may not be the best if you tow heavy alot.
Old Feb 3, 2007 | 04:38 PM
Ace's Avatar
Ace
Gear Vendors has your solution. I just put one in, love it:
https://www.dieseltruckresource.com/...d.php?t=135122
Best of both worlds, awesome 4.10 towing capability and low rpm highway cruising selectable with the flick of a switch.
Old Feb 3, 2007 | 05:14 PM
PeytonMaterne's Avatar
Umm, you could compromise with 3.54s you know.
Old Feb 3, 2007 | 06:54 PM
dodgenstein's Avatar
With 3.07s you will have to swap entire housings as the 3.07/Dana 71 (and 61 if 4wd) are a unique setup. The carrier and housing are offset to allow for a large pinion.
Old Feb 3, 2007 | 07:00 PM
If you are not towing heavy then 3.07's would be great!
With the 4:10's (assuming 235/85-16's), at 60 MPH you are running 2600 RPM in 4th and 2000 RPM in 5th. With 3.54's, that drops to 2250 and 1730, and with 3.07's you are at 1950 and 1500 - with 3rd becoming usable turning 3100 RPM @ 60 MPH!
Old Feb 3, 2007 | 07:31 PM
Id love to have a spliter or gear vendors et.. But I have a 1990 4X4 already for a parts
truck . Has the 307's and the truck only has 124,000 miles on it . Near a virgin I would say .
. Thanks for your info.
Old Feb 3, 2007 | 07:46 PM
G1625S's Avatar
Definitely run the 3.07's if you aready have them--that's a no-brainer. The whole swap won't take but half a day, and if you don't like it after a month, swap back and sell the 3.07's for the small fortune they're worth
Old Feb 4, 2007 | 01:17 AM
PapeCAT's Avatar
yeah I just did I long trip with 3.07's and getrag went over 85 most of the way on I-5... and yes I've been up to 55 in 3rd :O
Old Feb 4, 2007 | 09:05 AM
BHD's Avatar
BHD
I run around town and the back roads in 3rd or 4th, and use 5th mainly on the interstate. I do some heavy towing also and when pulling steep grades I will definately do more gear jamming than with the 4.10's but in my case anything was better than the slushbox making heat. You could always keep the 4.10s and run bigger tires.
Old Feb 4, 2007 | 09:11 AM
Ace's Avatar
Ace
I wonder how tall a tire would become unmanageable with 3.07s? Certainly, tire options would be a great reason to stay with the 4.10.
pred's Avatar
__________________
I thought that a 355 rear and 235-85-16 tires with a getrag would run at 2075 rpms at 70 mph, in 5th gear, If your info here is correct Dave, I need to reset my tach!
Peter.
Old Feb 4, 2007 | 10:05 AM
The info I posted is for 60 MPH (a sane towing speed). For 70 MPH the RPM in 5th are 2340, 2025, and 1750 respectively.
Old Feb 6, 2007 | 05:30 PM
BHD's Avatar
BHD
I have 265's on the truck now and after I get the 2.5" lift on (if Summit ever gets it to me) I want to run 285's. I have no probs with the tires on it now in fact I usually start in 2nd gear unloaded on the level. I did turn the anaroid(sp) aka smoke screw in 1 turn and that helps a little 'tween shifts.
Old Feb 6, 2007 | 05:50 PM
Bookshelf's Avatar
How's your mileage?
