285 BFG vs 315 BFG
Old Jun 29, 2004 | 02:41 PM
GONO2's Avatar
Question 285 BFG vs 315 BFG
Hello everyone.... Another Newbie Here.
I am the current owner of a 02 F250 PSD - BUT am very seriously considering trading for a Dodge. My dealer has the one I want on the lot. It's a 2500 diesel Laramie 4x4 with just about everything. Sticker price is $45,810 (I will be paying 1% less than invoice though)
This question is on tire size (one of 3 questions). BFG AT KO will be what I put on here before I take it home. Does anyone have a problem with 315's. Per the BFG website, it states 8.5 wide wheel minimum and these are only 8 wide (unless I'm wrong). I will be towing ocassionally and do not want a tire coming off the wheel.
Does anyone have pictures of 285's on their truck?
Thanks for the help!
Old Jun 29, 2004 | 04:15 PM
Mike67RS's Avatar
Hello again...The 315's will work fine with the 8" wheels. I had no rubs prior to the 2" leveling kit, and still have no rubs with it. Some have minor clearence issues at full lock, with the inside of the tire rubbing on the suspension arm. The 315's look good, but I would consider 4.10 gears if you plan on running them.
Sorry, no 285's here, but you can check my gallery for pics with the 315's.
Old Jun 29, 2004 | 04:46 PM
GONO2's Avatar
Very very nice looking truck!
I think your wheels may look better then the dull aluminum on the Laramie.... What's the general opinion on the factory wheels??
Old Jun 29, 2004 | 05:22 PM
Jeff in TD's Avatar
Well, I'll chime in. My general opinion is the factory doesn't offer decent wheels.
The chrome wheels appear to have some sort of chromed skin pressed over the wheels. The mag wheels appear to have a dull gray powder coat on much of the surface. Somehow they have managed to make their most expensive wheel look cheap... They all come with crummy looking plastic center covers.
Old Jun 29, 2004 | 06:01 PM
Dr.Kayak's Avatar
I think the new Alloy wheels look much better than the chrome over steel option. I bought a set for my 01. From what I have read the Alloy wheel has a clear coat over a brush Aluminum finish. I had this same finish on my 93 Dakota wheels. It was easy to keep clean and held up well.
I agree with Jeff, the center covers look lame. But they look better than the covers on my 01 wheels and the new ones look easier to keep clean.
Old Jun 30, 2004 | 04:36 AM
Dodgezilla's Avatar
I was going to buy 285s, but at the time, they cost almost twice what I paid for the 315s so my choice was easy. The 315s look great but you notice a difference in power..... Sorry, don't know about the 285s..
Old Jun 30, 2004 | 06:36 AM
nonford's Avatar
Zilla, you mention a notice in power, I take it that the big tires rob it. Is that right? I put 285's on mine and they appear to be holding well. I think I lost close to 1 mpg adding them. I'm basing that on my test drive, because I replaced them the day I took deleivery. But I am getting 17.3 back and forth to work everyday, 25 miles each way. I can live with that. I almost put the 315's on, but thought about it and put the 285's on.
Old Jun 30, 2004 | 08:09 AM
GONO2's Avatar
Anyone with pic's of 285's? Sure would like to see one....
Old Jun 30, 2004 | 10:52 AM
bulabula's Avatar
Gono, whats the truck you're looking at have for tires right now? 265's? To me, there isn't that much difference between 265's and 285's, but you can see the diff when you go to 315's.
My next set will be 315's - but at the rate that mine are wearing, it may be another year or so.
Old Jul 1, 2004 | 01:11 PM
Planetcat's Avatar
Pics of 285's.
Here are some pics of the 285/70R17 BFG A/T KO's on the OEM Chrome clad 17" wheels on my rig. . .
http://home.comcast.net/~planetcatte...m2500_pic1.jpg
http://home.comcast.net/~planetcatte...m2500_pic2.jpg
http://home.comcast.net/~planetcatte...m2500_pic3.jpg
http://home.comcast.net/~planetcatte...m2500_pic4.jpg
http://home.comcast.net/~planetcatte...m2500_pic5.jpg
http://home.comcast.net/~planetcatte...m2500_pic6.jpg
http://home.comcast.net/~planetcatte...m2500_pic7.jpg
Old Jul 1, 2004 | 06:05 PM
Dodgezilla's Avatar
Nonford,
When you go to 315s you basically change your gear ratio from 4:10s to 3:73s so that's the difference in bottom end power. You would think that that would give better mileage but I guess the rolling resistance of the wider tire negatively affects it more and I probably lost 1 mpg with the 315s.. I think the trucks look great with 315s. It makes it so the grill doesn't seem so big somehow...
taken5875
Nov 17, 2008 10:48 PM
JWillms81
23
May 13, 2008 09:30 PM
lawnman757
Jan 10, 2008 12:45 PM
wood_n_soldier
Jan 16, 2007 12:52 PM
HorseHauler
19
Jan 23, 2005 11:31 PM
