2500 4X4 single wheel rear brakes, pull axle?
Old 09-05-2009, 05:41 PM
c-bass's Avatar
I'm in the process of replacing my rear rotors and pads (looks like I'll also need a caliper) and I'm having a hell of a time trying to remove the rotors.
Do I need to pull the axle on a single wheel truck to get the rotors off?
If so, what seals,gaskets will I need to replace before I can reinstall everything?
Old 09-05-2009, 06:11 PM
dodge35000's Avatar
On the single rear wheel it should come off just like the front. Remove the brake caliper and the rotor should slide off. You only have to remove the axle shaft if it is a dual rear wheel axle.
Old 09-05-2009, 06:24 PM
hector's Avatar
Replaced 1 of my front rotors today.. It was a pain to get it off.. I used a large hammer & hit it several times on the back side while rotating it... The rust was holding it in place
Old 09-05-2009, 06:30 PM
c-bass's Avatar
In a way that sucks, I was hoping removing the axle was the key.
Looks like it's back to the drawing board...
Old 09-05-2009, 07:40 PM
adventuris's Avatar
tons of oil and a big hammer to get off
Old 09-05-2009, 07:44 PM
JP-4.5's Avatar
Bigger hammer... small sledge.. Mine came off very hard when replacing mine also.
Old 09-07-2009, 08:03 PM
c-bass's Avatar
I finally managed to get these off using very little hammering.
After the first round of hammering went nowhere I was looking things over while I took a break and decided pushing them from the rotors from the rear would be my best bet.
Several failed ideas later, I finally came across something that worked with a relatively small amount of force required on my part.
My solution? 12 Ton bottle jack between the shock mount bracket and the back of the rotor.
I didn't see it suggested in the forums, so hopefully if anyone comes across this post I'll save you some time and LOTS of hammering.
Looks like after all is said and done I'm also going to have to replace the calipers. I can't believe how bad the rear brakes were...it's a miracle the truck was stopping as "well" as it did if at all.
1985cucv
11-11-2009 06:19 PM
V.R.Wheeler
08-04-2007 01:00 PM
toyota31
04-03-2007 10:04 PM
ridofpwrstroke
08-25-2006 05:24 PM
ram350013
06-30-2006 03:18 PM
Quick Reply: 2500 4X4 single wheel rear brakes, pull axle?
