24 valve trouble
Old 06-15-2010, 05:50 PM
DieselRebel24's Avatar
24 valve trouble
ok so i checked the codes and i came up with: 0123-hi tps voltage, 1286-accelerator position sensor voltage hi, 370- fuel injection pump speed sensor/ position lost, 1694- no buss message received from ecm. kinda sounds like the tps is out to me
Old 06-15-2010, 07:19 PM
98.5Hotrod's Avatar
Try disconnecting the quad from your APS. Clear codes and recheck.
Old 06-20-2010, 08:25 PM
i completely un hooked it cleared the codes and it still misses
Old 06-20-2010, 08:28 PM
mishkaya's Avatar
Sounds like it's about time for a new TPS...
At least there are aftermarket ones available these days for not too much...
Old 06-23-2010, 06:29 PM
i got a new tps and it still does it...
Old 06-23-2010, 07:02 PM
mishkaya's Avatar
Time to start looking for bad grounds. They can typically cause this issue. If that doesn't cure it, you're probably looking at a new VP44...
Old 06-23-2010, 11:48 PM
i cleaned all my battery terminals. will clean all my ground connections tomorrow. will a vp44 go out without throwing any codes? if the vp is bad that would really **** me off since it is only a year old and has never seen anything below 16 psi of fuel
ridlangus123
12-30-2013 08:36 PM
Kylemm1002
13
06-16-2010 05:57 PM
DieselRebel24
20
07-02-2009 12:24 AM
kelley15
10-13-2005 02:51 PM
salty mule
01-06-2004 10:48 AM
Quick Reply: 24 valve trouble
