2001 won't start, need help
Old Nov 22, 2008 | 02:21 PM
Wild4kst8's Avatar
2001 won't start...
i dug around here & read tapping on the starter may work... well didn't work for me
batteries read 12V with multimeter & ignition off... lift pump will cycle but the vp doesn't sound like it is running... all i get is a small grown from under the hood along with clickity, clickity, clickity, clickity until the volt guage hits 8
Old Nov 22, 2008 | 02:37 PM
robert78.5's Avatar
Almost sounds like dirty battery cables, not grounding properly. There should be no noise from Injection pump.
Old Nov 23, 2008 | 07:27 PM
Dojman's Avatar
The cables were my first thought as well.
Old Nov 23, 2008 | 09:42 PM
nmen's Avatar
HOw old are the batteries?
Old Nov 24, 2008 | 01:05 PM
Invader's Avatar
Had same issue. Pull the cables, use a battery cleaner, and a terminal brush, and get those terminal rings (red/green protector ones). Install rings, reinstall cables (pound em down good.. terminals are tapered) and ensure tight.
I had chance to have the hood up and started the truck while doing my fogs, and when it went to start, it sparked up a good one on the positive terminal. Thus, not good contact. Poor contact leads to not enough current available to go to the starter = no start.
Fresh batteries help too, but only to a point.
Old Nov 24, 2008 | 02:15 PM
John Faughn's Avatar
More accurate measuring , full batteries should be 12.6-7 , should not drop below 10.5-11 , especially if the started is not turning over , a load test on the hole system is in order , alt. , starter and batteries .
Besides the above , it can be connections to all .
Old Nov 25, 2008 | 07:59 AM
Wild4kst8's Avatar
thanks for the replies
i jumped it with the wifes car & had to get a jump at work as well, so i ended up getting new batteries... fired right up this morning @ 25*F
the bolts have a bit of corrosion on them, is there an easy way to replace? i though i read somewhere (or maybe i was dreaming) that the ends unscrew to replace
Old Nov 25, 2008 | 09:43 AM
Which bolts are you referring to ?
If they come out [ or not , use blast , soak for a day ] put back together with anti seize .
grzpdlr
Jul 24, 2012 04:57 PM
heimrr
Dec 4, 2011 03:00 PM
98pace
Jun 20, 2009 08:51 AM
CB723
13
Oct 13, 2008 05:56 AM
gwright
13
Dec 19, 2007 05:54 PM
