20" Dually wheels?
Old 01-22-2008, 06:19 PM
Rhetorical's Avatar
20" Dually wheels?
Does anyone make them? I want to get bigger wheels but I don't want to go with the big rig wheels. Any good looking dually wheels out there?
Old 01-22-2008, 07:43 PM
blacksheep10's Avatar
eagle makes 19.5's that are about $200 apiece polished in 8x6.5
Old 01-22-2008, 08:57 PM
Rhetorical's Avatar
Yeah, but I don't want to run a heavy duty tire. Any other choices?
Old 01-22-2008, 09:34 PM
rip 112's Avatar
These are 19x 6.75. 20's gonna be hard.
http://www.customwheelsdirect.com/wh...l.php?id=59943
so are these
http://www.rimgod.com/Resalt.phpID=424
http://www.rimgod.com/Resalt.php?ID=425
Do some searching on the web. Most you're gonna find is 19s and the semi style rims.
Old 01-23-2008, 03:18 PM
jclaflin's Avatar
dually wheels
brentz wheels makes a direct bolt on 20 pricey though
Old 01-23-2008, 03:58 PM
rip 112's Avatar
Anything Dually will be pricy because of its offsets and whatnot.
Old 01-24-2008, 12:54 AM
GEN_X's Avatar
NO one makes a 20" dually wheel. NO ONE. Your only options are
::: - 16" - Not sure if you can use on a 3rd Gen
::: - 17"
::: - 19" ( milled down 19.5)
::: - 19.5" The lowest profile tire for this is 225/70-19.5 = 31" i believe
::: - 22" (milled down 22.5)
::: - 22.5 (semi wheel must use adaptors)
::: - 24" (milled down 24.5)
::: - 24.5" (semi wheel must use adaptors)
Those are the only options as of right now
Old 01-24-2008, 06:38 AM
Sinbadd's Avatar
I'll have to agree with GEN X, I haven't found any 20s for a dually either. I want somthing like a 20x8 so I can run a set of 35 inch tires. The 17 inch wheels that are available are kind of narrow, only 6.5" The 19.5s are a little wider at 6.75 but then tire choices are limited. The 22s (shaved 22.5s) are 8.25" wide but then the sidewall starts looking too low. for me 20s would have been ideal, too bad the market is not large enough for someone to make them.
kiszka6911
04-20-2010 04:18 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
RobG
09-05-2003 09:13 AM
Quick Reply: 20" Dually wheels?
