100 plate= wow
Old Oct 5, 2005 | 09:42 PM
wana12v's Avatar
100 plate= wow
well last this past weekend i got all the bombs done in my sig and I couldn't belive how powerful the truck felt, but when i was looking at my plate I really felt like I could've made one. So my friend who also has a 97 12 and an extra plate laying around was willing to let me try. He has guages and my old straight pipe, we drilled holes in his air box, and then I drew what is basically a 100 plate onto the plate and we went to the bench grinder. the plate looked rough, but we put it in full forward and went for a drive. the truck will black out the road, hit 35 psi with no known wastegate mods and fairly quikly peg the pyro. He was very impressed with the power, but the plate will need to be slid back a little.
Also I was thinking of making either a 100 or a zero for a play plate to run after I get my clutch just for playing, which makes more power the 100 or zero.
Old Oct 5, 2005 | 09:49 PM
Jeremy Cusick's Avatar
they should be about equal from the mid range on up. The 100 profile has the advantage of not dumping full fuel off idle. I love my hand ground 100, too!
TxDiesel007's Avatar
0 plate
you have pics in my gallery (pending approval currently) the zero is the most aggresseive plate out there, the 100 has the same top end but the zero is all out power on tap with lotsa smoke, the 100 will gradually feed then explode, as you found out, the zero is that explosion on all levels so to say...
If you wanna play? the 100 is what i chose, the zero is too much smoke, but if you want all out power, go with the zero... and get the smoke..
Tx
Old Oct 6, 2005 | 08:28 PM
argve's Avatar
Is there a diagram of either of these plates so that one can grind their own... not that I'm thinking of doing such a thing - Never would I want to turn up the power on my truck
Old Oct 6, 2005 | 08:33 PM
DustyRock's Avatar
There are pics in folks galleries. I have a pic of the three different plates side by side in my gallery.
Dusty
Old Oct 6, 2005 | 10:04 PM
Travis
please look at my gallery.. and u not turn up the truck is as believable as believeable as you not wanting to smoke someone... he he he he he he
Rick
Old Oct 8, 2005 | 01:22 PM
argve's Avatar
So you boys are just grinding them out on a snag grinder from a stock plate? Reason I ask is I have a stock plate and I highly doubt I will be putting that back in anytime soon.
Old Oct 8, 2005 | 02:04 PM
wana12v's Avatar
yes I just drew the profile on the plate with a marker, and then went at it with a bench grinder. The slope is a little less agressive than others ive seen but it fuels hard.
Old Oct 8, 2005 | 06:38 PM
I started on the bench grinder, smoothed that up w/ a dremel tool, then used and oil stone to polish it up.
Old Oct 8, 2005 | 07:12 PM
SmokinFive9 4x4's Avatar
Just a warning, don't forget to adjust the AFC lever when you put a new plate in or push it forward or back. If the lever slips under the plate it could possibly damage the pump.
smoke531
Sep 23, 2008 11:24 PM
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
West Coast
Jul 4, 2007 10:25 AM
West Coast
Jul 1, 2007 02:32 PM
banks twinram
Feb 5, 2005 10:38 AM
