1 Last Commander ?
Old 06-17-2007, 10:14 PM
Big T's Avatar
1 Last Commander ?
What is the other green plug of the controller for it has 3 wires coming from it can not find it any were in the directions?
Old 06-17-2007, 10:16 PM
DTR's 'Go to Guy'
vzdude's Avatar
IIRC thats where I plugged the Xzill box into it. Took the original Xzill controller off, and plugged the commander in. Do you have any power modules on the truck?
Old 06-17-2007, 10:22 PM
Big T's Avatar
Smarty on level 1
Old 06-17-2007, 10:26 PM
DTR's 'Go to Guy'
vzdude's Avatar
Thats a programmer, not a module. So I'm thinking you don't need it plugged into anything. Until you start stacking with a module that is!! LOL
Old 06-17-2007, 10:29 PM
Big T's Avatar
Thanks for thew info just wasnt sure if it went to the truck anywere. How doese the commander tell it to defuel the truck?
Old 06-17-2007, 10:37 PM
DTR's 'Go to Guy'
vzdude's Avatar
I don't think it can with a programmer, just the adjustable modules. Just have to adjust all the warnings to your liking and use the right foot to defuel!
Old 06-17-2007, 10:39 PM
DTR's 'Go to Guy'
vzdude's Avatar
BTW, did you buy the a-pillar mount? How did it fit?
Old 06-17-2007, 10:42 PM
Big T's Avatar
It looks SWEEEEEET like a glove good color match and tecture is dead on.
Old 06-17-2007, 10:46 PM
Big T's Avatar
One tip I have if you get one On the edge of the dash were the dash meets the door Lay a piece of duct tape on there. Then take a screw driver and manipulate the pillar mount back over top the screwdriver this way you wont mar up the dash.
Old 06-17-2007, 10:53 PM
shortbed rv's Avatar
I just did mine so I should know. For some reason I can only guess. I believe the second green plug is for the fuel pressure kit. Now I will go look.
Looks like fuel pressure kit connector (green).
Old 06-17-2007, 11:47 PM
qzilla's Avatar
The only other green plug I can think of has 6 wires in it and it is for the fuel pressure harness??
There should be a grey cable with 2 green plugs and 1 small black plug.
Then you plug the main harness in and it has your connections for boost, coolant and transmission. A two wire (black and white) connection for the Xzillaraider control. And then POwer and Ground.
The other plug has stuff for FP, RP and RPM plus a small 4 pin connector that has 3 wires in it for the translator and other accessories.
stock03
11-09-2006 11:27 PM
Monty
03-31-2004 08:34 PM
Barrett_Fodder
03-03-2004 07:15 PM
rossn2
02-23-2004 07:34 AM
y-knot
0
09-08-2003 05:29 PM
Quick Reply: 1 Last Commander ?
