06 auto trans temp
From the 05 manual, 06 should be the same.
Trans Over-Temp Lamp-On Message - Each time the cluster receives a trans over-temp lamp-on message from the PCM indicating that the transmission fluid temperature is 135° C (275° F) or higher, the indicator will be illuminated and a single chime tone is sounded. The indicator remains illuminated until the cluster receives a trans over-temp lamp-off message from the PCM, or until the ignition switch is turned to the Off position, whichever occurs first. The chime tone feature will only repeat during the same ignition cycle if the transmission over-temperature indicator is cycled off and then on again by the appropriate trans over-temp messages from the PCM.
I'd suggest you get a trans temp gauge so you can monitor it, towing--not towing--stop and go-- hot days etc....so you can have an idea of what effects those factors are having on it. The idiot dash warning light thing is set to high, imo.
Richpwb
08-15-2008 08:01 PM
