06 auto trans temp
Old Oct 15, 2008 | 08:44 PM
wrm's Avatar
wrm
06 auto trans temp
At what temp does the auto trans warning light come on ?
Old Oct 15, 2008 | 09:22 PM
deathracer's Avatar
Good question, I've wondered this one myself also. Rather have warning before damage instead of it being to late.
Old Oct 16, 2008 | 09:33 AM
coparam4x4's Avatar
Well I've had mine to 250* and no light. So I would say higher than that.
Old Oct 16, 2008 | 10:54 AM
DBLR's Avatar
I have heard its around 275. To me when the light does come on its to late as your trans is already toast.
Old Oct 16, 2008 | 11:37 AM
05 CTD2500's Avatar
From the 05 manual, 06 should be the same.
Trans Over-Temp Lamp-On Message - Each time the cluster receives a trans over-temp lamp-on message from the PCM indicating that the transmission fluid temperature is 135° C (275° F) or higher, the indicator will be illuminated and a single chime tone is sounded. The indicator remains illuminated until the cluster receives a trans over-temp lamp-off message from the PCM, or until the ignition switch is turned to the Off position, whichever occurs first. The chime tone feature will only repeat during the same ignition cycle if the transmission over-temperature indicator is cycled off and then on again by the appropriate trans over-temp messages from the PCM.
Old Oct 16, 2008 | 09:17 PM
wrm's Avatar
wrm
thanks thats what i needed to no
Old Oct 17, 2008 | 02:40 AM
TexasCTD's Avatar
I'd suggest you get a trans temp gauge so you can monitor it, towing--not towing--stop and go-- hot days etc....so you can have an idea of what effects those factors are having on it. The idiot dash warning light thing is set to high, imo.
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
Lenn
Jul 23, 2004 09:44 AM
MrDiesel
Jan 6, 2003 09:00 PM
