03 Reserve warning!!!
Old Jun 26, 2003 | 06:50 PM
nicksort's Avatar
My 01 had a low fuel warning light that came on with about 8or9 gal reserve left. <br><br>On my 03, when should I excpect the warning light to activate and how much fuel is left?????????<br>I am at 450mi on the odometer, with 1/3 capacity left in the fuel gauge and 135 left on the computer. This is still my first tank of fuel.<br><br>any Ideas?
Old Jun 26, 2003 | 07:07 PM
davec's Avatar
Re:03 Reserve warning!!!
Hmmm you must have gotten that special bottomless tank... <br>Today I was driving and didn't realize I was near empty. I had 11 miles for DTE forever, I drove way more than 11 miles. Then when I stopped and got back in I had zero DTE until I got to the pump, another 6 miles. Squeezed, and I mean squeezed, in 32.2 gallons when I was at 464* miles for that tankful. I still haven't figured out what's up with that overhead computer. I get 14.4 to 14.6 MPG consistently*, I must always drive uphill... [undecided]<br> I recall a few posts where folks say they have 3-4 gallons when the gauge is on E, and to completely fill the tank takes time when you get near the top. I can squeeze in a few more gallons if I'm patient...<br>*Adjusted for 315 tires
Old Jun 26, 2003 | 07:10 PM
nicksort's Avatar
This is why I am concerned.<br>I have no Idea, if or what, is the correct reading.<br>Are you also saying there is NO reserve warning lamp on the 03 trucks?
Old Jun 26, 2003 | 07:37 PM
LinearX's Avatar
My fuel light comes on religiously at an 1/8th of a tank left. I'm not sure how many gallons that equates to. I hit 538.27 (correct for my 315s) on the odometer and put 29.52 gallons in the truck. The DTE on the overhead was a zero for quite a while, so I really don't pay it much mind. I know that my fuel needle hadn't hit the peg past the 'E' so I'd say I could have gone a bit farther.
Old Jun 26, 2003 | 07:58 PM
butchera's Avatar
With my 2WD I can get just over 600 miles on a tank. Still haven't got the low fuel light to come on and had 570 miles when I filledit up with just over 30 Gal.
I'm getting right at 20 MPG.
Old Jun 26, 2003 | 08:09 PM
nicksort's Avatar
This still is confusing.....<br><br>LinearX says &quot;My fuel light comes on religiously at an 1/8th of a tank left.&quot;<br>Then Butchera says &quot;Still haven't got the low fuel light to come on and had 570 miles when I filledit up with just over 30 Gal&quot;<br><br>anyone else????
Old Jun 26, 2003 | 08:22 PM
LinearX's Avatar
While I've not been in another '03 when the fuel is getting low I can only speak for mine. It may be that every truck is different, but who knows? I think it's kind of extreme that mine comes on at 1/8th of a tank, but at least I know that I'll need to put fuel in it eventually.
Old Jun 26, 2003 | 09:08 PM
bulabula's Avatar
Mine'll take about 24-25 gallons when the low fuel alarm goes off. Its pretty consistent. I put in 23.7 today with no alarm.
Old Jun 26, 2003 | 09:54 PM
jshepherd's Avatar
It will actually hit the peg an run for awhile on that. I was on a long open road at about 3 am and not wanting to fill up at one of those small hardly used fuel stops then all of a sudden there were no stops.
Old Jun 26, 2003 | 10:36 PM
Rob_OBX's Avatar
DTE on overhead should read 0 when you are 10% full(3.5 gallons) left in tank. I got over 800 miles on a tank and it took 37.+ gallons to filler up to the neck.
Old Jun 27, 2003 | 12:24 AM
Nevada's Avatar
I have never been able to put in more than 25 gallons if I fill up right after the low fuel light illumintates. 10 gallons is a huge reserve for me.
Old Jun 27, 2003 | 07:07 AM
Rob_OBX's Avatar
You're not letting the foam settle down are you...
Old Jun 27, 2003 | 07:54 AM
100 Proof's Avatar
From: Eagle, Idaho. Please set your watch back 20 years when entering.
My last fill, 510 miles driven, no low fuel light, needle at ~1/8th, 25 gallons to fill. (I've only got about 800 miles on this puppy so this was also my first fill. ;D )<br><br>100 Proof
Old Jun 27, 2003 | 08:49 AM
nicksort's Avatar
thanks everyone - it looks like most of the warning lights activate at 1/8 of tank (9-10gal) and some with 3gals.<br>At least there IS a warning.....
Old Jun 27, 2003 | 08:57 AM
ck1's Avatar
ck1
I squeeze another 6 gals ( filled to the neck slowly but worth it) after it clicks off...go about 150 miles or so before coming off the full mark...light comes on at 1/8 with 60 miles on the DTE....foam is your gremlin here!...most i have put in my truck is 38.3 gallons...DC might be conservitive in stating gallonage in the tank to reduce running out of fuel situations....just my two cents<br>Cameron
