03 died while cruising
Old 06-16-2010, 08:29 AM
nismostate's Avatar
driving normally @ 40mph for about 10 min and all of a sudden it dies. figured it was my filter mounted lift pump so i went a replaced it with my back up but still doesn't run. the only codes showing are C Codes - AA, A7, and AC. checked the crank angle sensor and looks good. engine turns over and all but no sign of trying to start. i recalibrated the ECM to stock with the smarty jr but still no luck.
the C Codes read
A7 VIN checksum error.
AA PCM messages not received.
AC ABS messages not received.
could it be a blown fuse that's preventing it to run? is there another fuse box besides the one on the driver side engine bay? if not i've checked it all and it looks good. maybe its a bad FCA?
Old 06-16-2010, 10:01 AM
michael/edge's Avatar
my dad has benn having serious problems with his 03. one day it just died. then got it running. found out a cam sensor went bad. then he drove 5 hours one way. then on the way home it was blowing smoke and could only go 30 mph. went back to the shop. no codes, all pumps are fine. come to find out wires were rubbing on the frame. so he was driving home then it just died again.
he is on the verge of buying a 2011 powerstroke.
Old 06-16-2010, 10:11 AM
nismostate's Avatar
how did he determine the crank sensor went out? fault code?
do you know which side of the frame the wires were rubbing at?
btw: i've already taken the precaution of ziptieng the common wire that rubs thru under the alternator/ac compressor area.
Old 06-16-2010, 11:49 AM
nismostate's Avatar
found this..
https://www.dieseltruckresource.com/...luster+problem
Originally Posted by N.Johnson
A4 08 - No idea
A7 15 - VIN checksum error ( Smarty related on a 305/555 motor )
AA 15 - PCM mesage not received ( also smarty related )
B8 01 - No idea
00 00 - Done all diagnostic trouble codes have been displayed
Rip112 do it again, and check A4, B8. The last two numbers in the code are key starts. It goes up to 99. The AA and A7 are smarty and if you don't change the program will clear after 99.
is it my smarty that's causing the issue with the C Codes and preventing it to run?
Old 06-16-2010, 07:38 PM
it never did throw a code thats why they had trouble finding it. and the exact location where it was rubbing i guess it was somewhere in the engine compartment. and his truck is bone stock, the only add on is a jacobs exhaust brake. no chip no programmer, no nothing
HelenaTDI
15
12-24-2008 06:39 PM
boyd050
04-27-2008 02:47 PM
out_drsman
06-01-2004 09:11 PM
draebi
02-27-2004 03:23 PM
wanadieseltoo
03-12-2003 04:12 AM
Quick Reply: 03 died while cruising
