Boost and Pyro while cruising.
Old Dec 23, 2008 | 04:22 PM
HelenaTDI's Avatar
Just wondering if my boost range and pyro is normal for my relatively stock truck.
Cruising at 70mph boost is ~8-10psi, Pyro is ~700. Seems to me boost is too high.
While at 60mph boost is 4-5psi.
Any feedback would be appreciated. I plan on replacing the turbo with an HTT 62/71/13ss later this spring.
Old Dec 23, 2008 | 04:30 PM
KHoffman's Avatar
Sound about right to me. My truck runs in that range with the afc foward and stock plate foward.
Old Dec 23, 2008 | 04:34 PM
HelenaTDI's Avatar
Good deal. I wanted to be sure that the range was ok. By the way max boost on WOT is 22psi.
Old Dec 23, 2008 | 06:40 PM
Tate's Avatar
Your numbers are normal. Weather (especially wind) will affect those numbers. Nice days I'll br running about 8psi and 650 degrees on the highway at 80 mph. Last trip I did to Edmonton was -20C, was running 15-25psi and 800 degrees at the same speed.
Old Dec 23, 2008 | 06:48 PM
HelenaTDI's Avatar
Makes sense. Looks like I'm all good. Thanks for the explanation.
Old Dec 23, 2008 | 09:43 PM
KHoffman's Avatar
22 psi of boost is all you will get with th stock waste gate setting. I blocked my waste gate and now I have to be careful because I can hit 35 psi.
Old Dec 23, 2008 | 10:31 PM
smokin95's Avatar
Either my gauge is messed up or waste gate aint working right then cause i can get 42 psi boost
Old Dec 24, 2008 | 08:13 AM
Diesel_Dan's Avatar
your wastegate isnt working i have pretty much the same setup and thats what I get is 42psi and I know mine is working.
Old Dec 24, 2008 | 09:02 AM
HelenaTDI's Avatar
How do I check my waste gate? I never have adjusted the gate before. Can you let me know how to set it or block it?
Old Dec 24, 2008 | 09:44 AM
infidel's Avatar
Pretty common on the '94 and '95 that have the line going over the engine for the rubber part near the exhaust manifold to melt the line closed.
Result is no wastegate.
If you're only getting about 20 psi of boost your wastegate works.
To block the wastegate just cut the line to the wastegate actuator and stuff a 1/4" bolt down the end of the hose going away from the wastegate and hose clamp it.
Old Dec 24, 2008 | 10:52 AM
97 D-Tec's Avatar
4to 6 psi at 800 degrees at 70/ 8 psi at 850 degrees at 80/ WOT 44psi @ 1300 max.. when i had the stock turbo everythings the same except the egts were a tad bit lower for crusing but pegged the gauge (1500) at wot and the boost was at 40.
Old Dec 24, 2008 | 11:38 AM
HelenaTDI's Avatar
Good deal I'm going to take advantage of some more boost before I get my new turbo this spring. Thanks.
Old Dec 24, 2008 | 12:53 PM
Lil Dog's Avatar
Another idea is that if you plan to get a boost elbow in the future with a plate to control the wastegate, get a hose pincher from the local automotive store and just pinch the rubber line to the gate near the IP. That way you don't have to pull anything apart and just snap it over the hose and tighten. I did that until I started getting over 35 psi boost and got the elbow with the TST plate kit. I still use the elbow with my S300 turbo to tune the boost in the 45 ish range.
Old Dec 24, 2008 | 04:20 PM
Yellow Yota's Avatar
Isn't 45 PSI pushing the limits of a head gasket? I'm wanting to get a different charger, so I'm looking for info here.
Old Dec 24, 2008 | 04:22 PM
Tate's Avatar
When I disabled my wastgate, I removed the hose from the AFC to the turbo, and removed the tee at the AFC, so now its just the intake boost signal that goes to the IP.
