01 boost
01 boost
My buddy has a 01 with edge juice. he has a auto trans. we just put a J-hook on it to keep that waist gate closed. His boost is only around 25psi witch to me seems really low. I have a 01 manual and the edge comp and i push 25 on level one.
Hmm, 25 seems low on an HY with the wastegate adjusted. You're manual will have an HX35. I would be checking his system for boost leaks, so broken/leaking boots, intake planum gaskets, grid heater gaskets, etc.
X2. Your HX35 will easily over boost a HY found in 01 02 autos. When I did a J-hook with my old HY I had to mod it to build more then 25. It just wouldnt go any tighter, I only gained 3 lbs till I put a shorter spring on it.
The J-hook is a funny thing. Alot of guys will put it on and have range between stock 19-22 lbs and 30 lbs.
Others (like my situation with it) will put it on and have to really change it up before seeing results.
HOHN
45
10-08-2005 08:51 AM
triplenickel
08-23-2005 04:01 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
