What this?
Old 09-04-2011, 01:49 PM
DC199512V87's Avatar
What this?
what is this kdp, or killer dowel pin that ppl talk about and whats the big deal about it? iv seen it on here lots, tried searching but still know really have an idea of what it is. just trying to expand my knowledge database.....
Old 09-04-2011, 02:07 PM
mechmagcn's Avatar
The KDP is a locating dowel in the front of the block that tends to work loose over time. If it is allowed to fall out, it will be forced between the gears and the case, usually breaking a large chunk out and creating a huge oil leak.
Old 09-04-2011, 02:21 PM
bobfbigman's Avatar
Try this, on your web home page you should have a spot to click on for images, just type in killer dowel pin, alot of pictures of it
Old 09-05-2011, 07:42 AM
cj360trider's Avatar
if it does happen to you and a new case is warranted you will not have to tab it. the new case holds the pin captive. it cannot come out
Old 09-05-2011, 12:51 PM
patdaly's Avatar
Here is a perfect example, but many have had far worse hits.............
https://www.dieseltruckresource.com/...ght=whackamole
Old 09-05-2011, 01:15 PM
Diesel4blood's Avatar
I have the KDP repair kit. Now I just need to do it soon. I haven't really been driving the truck, but it's also been 114F and higher here in the desert!
This is my last Arizona summer! Man, I am sick and tired of this heat!!!!
Old 09-05-2011, 06:20 PM
move to Minot ND lol....then ull want to go back to the desert...its buttf*** cold there in the winter
Old 09-06-2011, 09:46 AM
infidel's Avatar
This will tell you what you need to know> http://www.tstproducts.com/dowelpinr...tfor94-98.aspx
Old 09-07-2011, 02:30 PM
i see.......thanks for the info. at what point mileage wis does this pin fall out usualy? im at 270000kms and i doubt its been looked at......
Old 09-07-2011, 02:35 PM
Lil Dog's Avatar
There is no rule for it, its an engine part and can fail at any time. The repair is cheap and easy in comparison to pulling the front gear cover to repair the damage. I did mine at 150,000 km an it was hanging 1/4" out. It may have stayed there or not, but it wasn't where it was supposed to be. I have 350,000 on it now and its worth not worrying about.
Old 09-07-2011, 05:28 PM
patdaly's Avatar
Or it might have already fallen out and not hit anything........
Old 09-08-2011, 09:45 AM
infidel's Avatar
I've seen KDP cracked case damage ranging from 48-325k miles.
Mileage makes no difference, it can happen any time.
Old 09-08-2011, 10:38 PM
J.Suplanski's Avatar
Talking Dowel pin the dreaded
HAD MINE DONE AT 200,OOO BUT IT HAD HARDLY MOVED! CHANGED IT ANYWAY! GRUMPY JOHN 4X4
Old 09-10-2011, 11:48 AM
cromulius's Avatar
If you take the cover off to look at it definately do the fix. I would do it sooner than later cause its not hard to do. My only mistake was jacking around with trying to get my fan off for a while until infidel or somebody told me to just remove the fan pulley bolts so you can remove the fan and its mount all in one. After that its a piece of cake if you remember how the ess wire is routed and where the longer bolts go. I installed the new seal on my work bench. I couldnt imagine trying to install the seal after.
