TXDTR #8 Forum for the Texas chapter #8
North Texas DTR #8 November GTG
Old Oct 30, 2007 | 04:51 PM
  #61
RowJ's Avatar
Originally Posted by bigredBCS
Robert, .....everyone i know that ran the tst box had problems with it.
Yup! Just check the classifieds. Lots of 3rd gen TST's and Edges, etc.
No Smarty's.
RJ
Old Oct 30, 2007 | 08:08 PM
  #62
Vern Calhoun's Avatar
Which of you'ns have installed the pyro with removing the turbo and which have done it with the vaccum/magnent trick? The reason I ask is I have yet to do mine AND install the fuel pres. line to diaphram and hose to it as well. If yall dont mind I'll wait one more weekend and we could do it out there. It's completely up to yall. Vern Edit - It turns out I have either a three day or four day weekend (It's up to the BDE CDR) and I'm not on the duty roster so I'll be there come H*ll or High water.
Old Oct 30, 2007 | 08:10 PM
  #63
bnold's Avatar
I've done it both ways... Never had an issue...
Will say that I HATE fuel isolators though!!
Old Oct 30, 2007 | 08:14 PM
  #64
You think we/I would be happier and better off if it is hooked up direct? I'm new to this so whatever has worked for yall I will probaly do on mine. Plus I could send the isolator and SS hose back for a refund!! Thanks, Vern
Old Oct 30, 2007 | 08:17 PM
  #65
hotdram's Avatar
Hook it up direct. An isolator will most likely fail over time and cause you more grief than it's worth. Properly installed, a mechanical gauge in the cab won't leak. Most folks here are running 'em that way.
~Rob
Old Oct 30, 2007 | 09:16 PM
  #66
bnold's Avatar
Yep and have a needle valve inline so if there ever was a leak it can be turned off easily
Old Oct 31, 2007 | 01:17 AM
  #67
TexasCTD's Avatar
Robert , smarties already add all the pressure you need. And wveryone i know that ran the ts box had problems with it.
I knew the Smarty could add pressure, but that is something I want to turn down while not "playing". I want that particular item to be adjustable. I don't recall hearing about alot of problems with the TS-MP8. Maybe I need to watch the threads about them a little closer.
I don't want to have to "unload"/"Reload" the Smarty to have or NOT have extra pressure. Luvnacummins I believe was around 570ish with just a Smarty/MP8/large single turbo.....while still running stock trans.
He has twins now though.
I believe pressure in moderation won't hurt much. Running around with pressure all the time will. right?
Old Oct 31, 2007 | 01:19 AM
  #68
TexasCTD's Avatar
No Smarty's.
RJ
Yep! You would have to pry my Smarty from my cold dead hands!!!
Old Oct 31, 2007 | 01:20 AM
  #69
TexasCTD's Avatar
If I decide to lose the isolator and go straight into the cab with the fuel....where/what is a good needle valve to go with? Suggestions on the valve and where to buy? TIA
Old Oct 31, 2007 | 07:55 AM
  #70
RowJ's Avatar
I've heard NAPA has them? Been discussed alot in the past...try a search.
Got mine from Graingers!
RJ
Old Oct 31, 2007 | 09:35 AM
  #71
Diesel-Dan's Avatar
Man...just drill it and dont worry about the shavings.....they will pass throught the turbo with out any issue due to its spinning at VERY low RPM at idle and the exhaust fins are very durable. I have never once had an issue. IF you really wanted to keep shavings out of the exhaust.....drill it with the truck running. Just ware some glasses.
Old Oct 31, 2007 | 09:36 AM
  #72
Diesel-Dan's Avatar
I second that........
Look here for needle valves:
http://www.calibex.com/Needle-Valve/...FED4B646FEB3A9
Just found it on a random search.....
Old Oct 31, 2007 | 09:46 AM
  #73
bnold's Avatar
I got my needle valve from surplus center for a buck... Nice stout NPT tapped, good locking valve that is stiff to turn so it doesn't wander.
I've tapped one and had a bit of tape over the exhaust to create some back pressure... them shavings just flew out the engine... Safety glasses would have been nice!
Old Oct 31, 2007 | 12:00 PM
  #74
TexasCTD's Avatar
http://cgi.ebay.com/ebaymotors/Curt-...spagenameZWDVW
I just bought a CURT Gooseneck Hitch plate to put in my 5th wheel hitch rails. I hope I never need it, but if the need arises........you can't pull a GN without it.
Old Oct 31, 2007 | 12:02 PM
  #75
TexasCTD's Avatar
RJ
Ok thanks. I'll prob try NAPA first.
I am just not familiar with needle valves....brands, types etc. Not sure exactly what I should buy for my set up.
